i tried installing arangodb but i do not see how i can start or use it on nixos. is there a pointer to the instruction?
caught exception during prepare of feature ‘Logger’: cannot write file
thanks for yor help.
Hi, @wpoosanguansit.
It looks like there is no NixOS module for arangodb
at this time. PRs are welcome!
To get started, you’ll probably want to configure a systemd service with the systemd.services.<name>
options. NixOS Search
You could start by trying to modify a different module. Maybe the MongoDB one would work? https://github.com/NixOS/nixpkgs/blob/b43c4d8b758a3965067b24f3796cdd532756a2ce/nixos/modules/services/databases/mongodb.nix
- Ryan
There is also this PR that hasn’t been merged arangodb: Add arangodb as a NixOS service by babariviere · Pull Request #40167 · NixOS/nixpkgs · GitHub that might be a good starting point.
- Ryan
On a dev machine I am using:
{ config, lib, pkgs, ... }:
with lib;
cfg = config.services.arangodb;
writeConfFile = filename: attrs: pkgs.writeText filename (
concatStringsSep "\n" (mapAttrsToList (section: attrs2: ''
[${section}]
${concatStringsSep "\n" (mapAttrsToList (k: v: "${k} = ${if builtins.isBool v then boolToString v else toString v}") attrs2)}
'') attrs
###### interface
options = {
services.arangodb = {
enable = mkEnableOption "ArangoDB server";
package = mkOption {
default = pkgs.arangodb;
type = types.package;
description = "Which ArangoDB derivation to use";
dataDir = mkOption {
type = types.path;
example = "/var/db/arangodb";
default = "/var/db/arangodb";
description = "ArangoDB data dir";
arangodConf = mkOption {
type = types.attrs;
default = {
server.endpoint = "tcp://127.0.0.1:8529";
server.storage-engine = "auto";
server.uid = "arangodb";
database.directory = cfg.dataDir;
javascript.startup-directory = "${cfg.package}/share/arangodb3/js";
javascript.app-path = cfg.dataDir;
log.level = "info";
log.file = "${cfg.dataDir}/arangodb.log";
arangoshConf = mkOption {
type = types.attrs;
default = {
console.pretty-print = true;
server.endpoint = cfg.arangodConf.server.endpoint;
server.password = "";
###### implementation
config = mkIf cfg.enable {
users.extraUsers.arangodb = {
name = "arangodb";
group = "arangodb";
uid = /*config.ids.uids.arangodb*/600;
description = "ArangoDB server user";
users.extraGroups.arangodb.gid = /*config.ids.gids.arangodb*/600;
boot.kernel.sysctl."vm.max_map_count" = lib.mkDefault 256000;
(pkgs.stdenv.mkDerivation {
name = "arangodb-cli-wrappers";
nativeBuildInputs = [ pkgs.makeWrapper ];
buildCommand = ''
mkdir -p $out/bin
makeWrapper ${cfg.package}/bin/arangosh $out/bin/arangosh \
--argv0 ${cfg.package}/bin/arangosh \
--add-flags "--configuration ${writeConfFile "arangosh.conf" cfg.arangoshConf}"
systemd.services.arangodb = rec {
description = "ArangoDB server";
after = [ "network.target" ];
serviceConfig = {
ExecStart = "${cfg.package}/bin/arangod --configuration ${writeConfFile "arangod.conf" cfg.arangodConf}";
User = "arangodb";
Group = "arangodb";
LimitNOFILE = 100000;
PermissionsStartOnly = true;
preStart = ''
install -d -m0700 -o ${escapeShellArg serviceConfig.User} -g ${escapeShellArg serviceConfig.Group} ${escapeShellArg cfg.dataDir}
# just in case of uid/gid change
chown -R ${escapeShellArg "${serviceConfig.User}:${serviceConfig.Group}"} ${escapeShellArg cfg.dataDir}
I will submit a PR after some battle-testing
