jakubgs
October 14, 2020, 12:12pm
1
Are there any concrete rules in what order things appear in PATH
when provided in buildInputs
or other arguments that modify PATH
I made this simple derivation to test this:
{ pkgs ? import <nixpkgs> { } }:
pkgs.stdenv.mkDerivation {
name = "nix-path-test";
buildInputs = with pkgs; [ vim go ];
phases = [ "buildPhase" ];
buildPhase = ''
echo $PATH | tr ':' '\n'
And the result I get is:
/nix/store/71n1xcigc00w3z7yc836jqcx9cb2dys8-patchelf-0.9/bin
/nix/store/m6h7zh8w6s52clnyskffj5lbkakqgywn-gcc-wrapper-9.2.0/bin
/nix/store/b3zsk4ihlpiimv3vff86bb5bxghgdzb9-gcc-9.2.0/bin
/nix/store/0k65d30z9xsixil10yw3bwajbdk4yskv-glibc-2.30-bin/bin
/nix/store/x0jla3hpxrwz76hy9yckg1iyc9hns81k-coreutils-8.31/bin
/nix/store/n48b8n251dwwb04q7f3fwxdmirsakllz-binutils-wrapper-2.31.1/bin
/nix/store/hrkc2sf2883l16d5yq3zg0y339kfw4xv-binutils-2.31.1/bin
/nix/store/qx3f6nrqgsb0y0sswy4zdw0sv86dwk9x-vim-8.2.0013/bin
/nix/store/fkvrggd8q3b543h6bal3clg9arzq6qvq-go-1.14.8/bin
/nix/store/97vambzyvpvrd9wgrrw7i7svi0s8vny5-findutils-4.7.0/bin
/nix/store/dqq1bvpi3g0h4v05111b3i0ymqj4v5x1-diffutils-3.7/bin
/nix/store/p34p7ysy84579lndk7rbrz6zsfr03y71-gnused-4.8/bin
/nix/store/b0vjq4r4sp9z4l2gbkc5dyyw5qfgyi3r-gnugrep-3.4/bin
/nix/store/c8balm59sxfkw9ik1fqbkadsvjqhmbx4-gawk-5.0.1/bin
/nix/store/g7dr83wnkx4gxa5ykcljc5jg04416z60-gnutar-1.32/bin
/nix/store/kkvgr3avpp7yd5hzmc4syh43jqj03sgb-gzip-1.10/bin
/nix/store/rw96psqzgyqrcd12qr6ivk9yiskjm3ab-bzip2-1.0.6.0.1-bin/bin
/nix/store/dp6y0n9cba79wwc54n1brg7xbjsq5hka-gnumake-4.2.1/bin
/nix/store/hrpvwkjz04s9i4nmli843hyw9z4pwhww-bash-4.4-p23/bin
/nix/store/xac1zfclx1xxgcd84vqb6hy3apl171n8-patch-2.7.6/bin
/nix/store/mm0w8jc58rn01c4kz2n9jvwd6bibcihs-xz-5.2.4-bin/bin
Which shows that both vim
and go
appear in the order they were specified in buildInputs
, but they also appear in the middle of PATH
, rather than in the beginning or at the end.
I assume the order of entries in PATH
has to be deterministic, but what are some other rules that decide the order of things?
I won’t claim to have looked closely enough to know, but in case no one else turns up with a definitive answer, in most cases this is governed by the implementation in https://github.com/NixOS/nixpkgs/blob/6bae92a3eea8c56999d9c76417809a81e0fedfa6/pkgs/stdenv/generic/setup.sh
Thanks. That makes sense.
So I can see PATH
being set from _PATH
Which appears to be configured here via addToSearchPath
from within activatePackage
fi
# Only dependencies whose host platform is guaranteed to match the
# build platform are included here. That would be `depsBuild*`,
# and legacy `nativeBuildInputs`, in general. If we aren't cross
# compiling, however, everything can be put on the PATH. To ease
# the transition, we do include everything in thatcase.
# TODO(@Ericson2314): Don't special-case native compilation
if [[ ( -z "${strictDeps-}" || "$hostOffset" -le -1 ) && -d "$pkg/bin" ]]; then
addToSearchPath _PATH "$pkg/bin"
fi
if [[ "$hostOffset" -eq 0 && -d "$pkg/bin" ]]; then
addToSearchPath _HOST_PATH "$pkg/bin"
fi
if [[ -f "$pkg/nix-support/setup-hook" ]]; then
source "$pkg/nix-support/setup-hook"
fi
Which is used here from _activatePkgs
And packages seem to be coming from pkgAccumVarVars
which is defined here:
But then the trail gets very confusing due to some high level Bash magic, but I can see that the variables like buildInputs
appear to be collected via findInputs
Which in turn is another function full of Bash dark magic:
propagatedTargetDepFiles
# Platform offsets: build = -1, host = 0, target = 1
declare -a allPlatOffsets=(-1 0 1)
# Mutually-recursively find all build inputs. See the dependency section of the
# stdenv chapter of the Nixpkgs manual for the specification this algorithm
# implements.
findInputs() {
local -r pkg="$1"
local -ri hostOffset="$2"
local -ri targetOffset="$3"
# Sanity check
(( "$hostOffset" <= "$targetOffset" )) || exit -1
local varVar="${pkgAccumVarVars[$hostOffset + 1]}"
local varRef="$varVar[\$targetOffset - \$hostOffset]"
local var="${!varRef}"
Quite the rabbit hole…
it’s a bit of a rabbit hole to support cross compilation, in which only packages which can be executed by the host should be available on the PATH.
Is there something you are trying to solve by ordering the PATH? Generally in nixpkgs, you just need one occurrence of a package.
Not really, I’m just trying to understand how things work under the hood. Thanks for explaining.
