eljamm
May 15, 2024, 4:50pm
22
These are the only GLX entries I get when running with LD_DEBUG=libs
[15/05/2024 17:48:44 PM] 1552**ACCESSTOKEN**19: find library=libGLX.so.**ACCESSTOKEN** [**ACCESSTOKEN**]; searching
[15/05/2024 17:48:44 PM] 1552**ACCESSTOKEN**19: trying file=/nix/store/6v6k2g45hrxazgbbw3zyv6pl8914**ACCESSTOKEN**v1y-libXxf86vm-1.1.5/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:48:44 PM] 1552**ACCESSTOKEN**19: trying file=/nix/store/lsp7hk1ppjv4**ACCESSTOKEN**3q8h191p929wycbk**ACCESSTOKEN**r3-systemd-minimal-libs-255.4/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:48:44 PM] 1552**ACCESSTOKEN**19: trying file=/nix/store/msi95r4426zlfbmzr1a9v45b2vgqaail-discord-rpc-3.4.**ACCESSTOKEN**/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:48:44 PM] 1552**ACCESSTOKEN**19: trying file=/nix/store/4ja9a94kxjqwm65c5bpnrnsa5rffb**ACCESSTOKEN**ij-glfw-3.4/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:48:44 PM] 1552**ACCESSTOKEN**19: trying file=/nix/store/qvacibysn**ACCESSTOKEN**z5478vsbjcs35kh2bpykyk-pipewire-1.**ACCESSTOKEN**.5-jack/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:48:44 PM] 1552**ACCESSTOKEN**19: trying file=/nix/store/apab5i73dqa**ACCESSTOKEN**9wx**ACCESSTOKEN**q27b6fbhd1r18ihl-glibc-2.39-31/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:48:44 PM] 1552**ACCESSTOKEN**19: trying file=/nix/store/nrwkk6ak3rgkrxbqhsscb**ACCESSTOKEN**1jpzmslf2r-xgcc-13.2.**ACCESSTOKEN**-libgcc/lib/libGLX.so.**ACCESSTOKEN**
Edit: I ran the launcher with:
$ steam-run atlauncher
and the game worked…
jchw
May 15, 2024, 4:58pm
23
Interesting: this should be provided by libglvnd
That is a reasonable solution; under the hood steam-run runs things in an FHS environment. It’s a bit heavy-handed but usually pretty effective.
If this is working, that means there’s some lib missing in the Nix derivation for ATLauncher. I’ll find what’s causing that. Must’ve been something in 3.4.36.3
I guess? I’m guessing you’ve also tried 3.4.36.4
eljamm
May 15, 2024, 5:02pm
25
When running with steam-run, there are more glx libraries, so I guess the ones from mesa get loaded in this case:
Summary
[15/05/2024 17:57:17 PM] 1553887: find library=libxcb-glx.so.**ACCESSTOKEN** [**ACCESSTOKEN**]; searching
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/6v6k2g45hrxazgbbw3zyv6pl8914**ACCESSTOKEN**v1y-libXxf86vm-1.1.5/lib/libxcb-glx.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/lsp7hk1ppjv4**ACCESSTOKEN**3q8h191p929wycbk**ACCESSTOKEN**r3-systemd-minimal-libs-255.4/lib/libxcb-glx.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/msi95r4426zlfbmzr1a9v45b2vgqaail-discord-rpc-3.4.**ACCESSTOKEN**/lib/libxcb-glx.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/4ja9a94kxjqwm65c5bpnrnsa5rffb**ACCESSTOKEN**ij-glfw-3.4/lib/libxcb-glx.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/lib64/libxcb-glx.so.**ACCESSTOKEN**
[15/05/2024 17:57:25 PM] 1553887: calling fini: /lib64/libGLX.so.**ACCESSTOKEN** [**ACCESSTOKEN**]
[15/05/2024 17:57:25 PM] 1553887: calling fini: /lib64/libGLX_mesa.so.**ACCESSTOKEN** [**ACCESSTOKEN**]
[15/05/2024 17:57:25 PM] 1553887: calling fini: /lib64/libxcb-glx.so.**ACCESSTOKEN** [**ACCESSTOKEN**]
[15/05/2024 17:57:17 PM] 1553887: find library=libGLX.so.**ACCESSTOKEN** [**ACCESSTOKEN**]; searching
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/6v6k2g45hrxazgbbw3zyv6pl8914**ACCESSTOKEN**v1y-libXxf86vm-1.1.5/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/lsp7hk1ppjv4**ACCESSTOKEN**3q8h191p929wycbk**ACCESSTOKEN**r3-systemd-minimal-libs-255.4/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/msi95r4426zlfbmzr1a9v45b2vgqaail-discord-rpc-3.4.**ACCESSTOKEN**/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/4ja9a94kxjqwm65c5bpnrnsa5rffb**ACCESSTOKEN**ij-glfw-3.4/lib/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/lib64/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: calling init: /lib64/libGLX.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: find library=libGLX_mesa.so.**ACCESSTOKEN** [**ACCESSTOKEN**]; searching
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/6v6k2g45hrxazgbbw3zyv6pl8914**ACCESSTOKEN**v1y-libXxf86vm-1.1.5/lib/libGLX_mesa.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/lsp7hk1ppjv4**ACCESSTOKEN**3q8h191p929wycbk**ACCESSTOKEN**r3-systemd-minimal-libs-255.4/lib/libGLX_mesa.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/msi95r4426zlfbmzr1a9v45b2vgqaail-discord-rpc-3.4.**ACCESSTOKEN**/lib/libGLX_mesa.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/nix/store/4ja9a94kxjqwm65c5bpnrnsa5rffb**ACCESSTOKEN**ij-glfw-3.4/lib/libGLX_mesa.so.**ACCESSTOKEN**
[15/05/2024 17:57:17 PM] 1553887: trying file=/lib64/libGLX_mesa.so.**ACCESSTOKEN**
I’m actually using 3.4.28.1
since I don’t a Microsoft account and I needed to open the game offline. I thought newer versions of the launcher might have the same problem since it didn’t work for @noofel.rouge either. Could this be because I’m running an older version?
Edit: I’ve added libglvnd
to the wrapper and now the game works even without steam-run
Okay, that’s good. Was the error occurring when launching the launcher itself or an instance?
eljamm
May 15, 2024, 5:12pm
27
It was happening when I launched an instance.
Weird, I’m unable to get an instance running even with 3.4.28.1
. I can’t even figure out any more libraries that it needs since the actual Minecraft instances need these libs, and not the launcher. steam-run atlauncher
works with all versions.
eljamm
May 15, 2024, 6:58pm
29
This is how I’m currently overriding the package:
(atlauncher.overrideAttrs rec {
pname = "atlauncher";
version = "3.4.28.1";
src = fetchurl {
url = "https://github.com/ATLauncher/ATLauncher/releases/download/v${version}/ATLauncher-${version}.jar";
hash = "sha256-IIwDMazxUMQ7nGQk/4VEZicgCmCR4oR8UYtO36pCEq4=";
installPhase = ''
runHook preInstall
mkdir -p $out/bin $out/share/java
cp $src $out/share/java/ATLauncher.jar
makeWrapper ${jre}/bin/java $out/bin/${pname} \
--prefix LD_LIBRARY_PATH : "${lib.makeLibraryPath [ xorg.libXxf86vm udev discord-rpc libglvnd ]}" \
--add-flags "-jar $out/share/java/ATLauncher.jar" \
--add-flags "--working-dir \"\''${XDG_DATA_HOME:-\$HOME/.local/share}/ATLauncher\"" \
--add-flags "--no-launcher-update"
mkdir -p $out/share/icons/hicolor/scalable/apps
cp $ICON $out/share/icons/hicolor/scalable/apps/${pname}.svg
runHook postInstall
Without steam-run
, the instance I’m running is the vanilla Minecraft 1.20.6 with the following instance settings:
General
Account Override → Default
Enable Discord Integration? → No
Java/Minecraft
Didn’t touch the Java parameters (openjdk-21+35)
Use Java Provided By Minecraft? → No
Disable Legacy Launching? → Default
Use System GLFW? → No
Use System OpenAL? → No
Commands → No
I should also note that I have no sound when not running with steam-run
, but that’s another issue, I guess.
It looks like what you’ve overridden is the same as what I’ve done.
Some differences I can note at first glance are:
I’m not putting ATLauncher in my system, rather in my home.
I’m using a custom HM module for ATLauncher but it doesn’t exactly add anything too different.
Sound works for me.
Just to confirm, you’re on X11, right?
All right so I ditched my custom HM module and copy pasted what you sent, this time I’ve gotten logs which were not there before for whatever reason:
[16/05/2024 00:36:20 am] Could not start dynamically linked executable: **USERSDIR**/runtimes/minecraft/java-runtime-delta/linux/java-runtime-delta/bin/java
[16/05/2024 00:36:20 am] NixOS cannot run dynamically linked executables intended for generic
[16/05/2024 00:36:20 am] linux environments out of the box. For more information, see:
[16/05/2024 00:36:20 am] https://nix.dev/permalink/stub-ld
[16/05/2024 00:36:20 am] Oh no. Minecraft crashed. Please check the logs for any errors and provide these logs when asking for support.
Given that ATLauncher isn’t working even on older versions which were confirmed to be working on NixOS, I suspect that updates to its dependencies have caused it to fail.
eljamm
May 15, 2024, 7:16pm
32
Yup.
This means that ATlauncher is trying to load its java runtime, which won’t work. Just choose the jre from the nix store in your settings:
Those runtimes probably won’t work on NixOS. You should try using the jre from the nix store that comes pre-installed with the program, instead.
You can set it by going to the Settings > Java/Minecraft > Java Path menu.
You might also want to untick the Use Java Provided By Minecraft? box as well.
As different Minecraft versions might need different java versions, you might want to override the jre you have:
(pkgs.atlauncher.override {
jre = te…
That worked for me. Though I’m worried that anyone using this package would run into this issue and may not always know the fix for it. But there’s no real way to solve this declaratively without using NixOS modules AFAIK.
eljamm
May 15, 2024, 8:09pm
34
Perhaps it’s possible to patch out the logic that downloads the jre in the first place, but what we can currently do is add this information to the Wiki, at least.
A patch might be quite difficult; though, I’ll ask the upstream dev of a possible patch. But yes, we should add this to the Wiki sometime soon.
A more trivial solution would be to set these version mapping manually in the package or a NixOS module according to what you’ve mentioned earlier:
eljamm
May 15, 2024, 8:36pm
36
I fixed the sound issue by adding alsa-lib
. I also tried with pulseaudio
and it works. I’m using pipewire, by the way, but I think adding those two would be better for compatibility reasons.
It would be nice if a way to bypass all java declarations would be introduced in upstream.
Some thing like atlauncher --javapath
Edit: It would actually be better if we could define multiple ones, like how prismlauncher does with it
PRISMLAUNCHER_JAVA_PATHS
, so we could do something like this:
++ additionalLibs;
runtimePrograms = [
xorg.xrandr
mesa-demos # need glxinfo
pciutils # need lspci
++ additionalPrograms;
[ "--prefix PRISMLAUNCHER_JAVA_PATHS : ${lib.makeSearchPath "bin/java" jdks}" ]
++ lib.optionals stdenv.isLinux [
"--set LD_LIBRARY_PATH ${addOpenGLRunpath.driverLink}/lib:${lib.makeLibraryPath runtimeLibs}"
# xorg.xrandr needed for LWJGL [2.9.2, 3) https://github.com/LWJGL/lwjgl/issues/128
"--prefix PATH : ${lib.makeBinPath runtimePrograms}"
inherit (prismlauncher') meta;
prismlauncher works really well, i just use it now, works perfectly fine.
eljamm
May 16, 2024, 11:16am
38
I’ve added a Wiki entry for this in wait of a fix upstream.
A fix for one of the issues mentioned here has been merged to master; anyone is welcome to track its journey to nixos-unstable
here .
Hey people, I am late to the party but ATlauncher seems to be working without issue now. I only have jdk installed in my environment.systemPackages and in ATlauncher’s settings unchecked “use the provided java” and “intergrated discord” options, with these ATlauncher works perfectly fine.
eljamm
August 5, 2024, 2:04pm
41
Just out of curiosity, does it not work if you have Discord Integration
enabled?
