I have been trying to set up my nix configuration (GitHub - jimkoen/homelab: my homelab) to use sops-nix for secret management. I’ve been following the guide and have managed to load secrets when running nix repl.
Specifially, I am trying to load my Cloudflare API token in order to trigger ACME challenges on the host. The key in secrets.yaml
is called “CLOUDFLARE_DNS_API_TOKEN” and seems to load just fine when using the repl:
jimkoen@fedora ~/s/nix-config (main)> nix repl .
Nix 2.25.3
Type :? for help.
warning: Git tree '/home/jimkoen/src/nix-config' is dirty
Loading installable 'git+file:///home/jimkoen/src/nix-config#'...
Added 2 variables.
nix-repl> nixosConfigurations.paperless-ngx.config.sops.secrets.CLOUDFLARE_DNS_API_TOKEN
format = "yaml";
gid = 0;
group = null;
key = "CLOUDFLARE_DNS_API_TOKEN";
mode = "0400";
name = "CLOUDFLARE_DNS_API_TOKEN";
neededForUsers = false;
owner = null;
path = "/run/secrets/CLOUDFLARE_DNS_API_TOKEN";
reloadUnits = [ ... ];
restartUnits = [ ... ];
sopsFile = "/nix/store/iplskddnx91vv49mi2bjwav1r6j0xpk6-source/secrets.yaml";
sopsFileHash = "fe2e04448bc1bdb0d030a548e31d52eb4ed15fc70cfcda1f54c634bbf20b06b4";
uid = 0;
Yet, when running nix flake check
, I’m encountering the following error:
jimkoen@fedora ~/s/nix-config (main)> nix flake check
evaluation warning: system.stateVersion is not set, defaulting to 25.05. Read why this matters on https://nixos.org/manual/nixos/stable/options.html#opt-system.stateVersion.
error:
… while checking flake output 'nixosConfigurations'
at /nix/store/iplskddnx91vv49mi2bjwav1r6j0xpk6-source/flake.nix:40:5:
39| {
40| nixosConfigurations.nixcontainer = let
41| username = "jimkoen";
… while checking the NixOS configuration 'nixosConfigurations.paperless-ngx'
at /nix/store/iplskddnx91vv49mi2bjwav1r6j0xpk6-source/flake.nix:56:5:
55|
56| nixosConfigurations.paperless-ngx = let
57| username = "jimkoen";
… while evaluating the option `system.build.toplevel':
… while evaluating definitions from `/nix/store/w86f55hf97fr811mgc5dks24nak5jy0n-source/nixos/modules/system/activation/top-level.nix':
… while evaluating the option `warnings':
… while evaluating definitions from `/nix/store/w86f55hf97fr811mgc5dks24nak5jy0n-source/nixos/modules/system/boot/systemd.nix':
… while evaluating the option `systemd.services."acme-paperless-ngx.home.jimkoen.com".serviceConfig':
… while evaluating definitions from `/nix/store/w86f55hf97fr811mgc5dks24nak5jy0n-source/nixos/modules/security/acme':
… while evaluating the option `security.acme.certs."paperless-ngx.home.jimkoen.com".environmentFile':
… while evaluating definitions from `/nix/store/iplskddnx91vv49mi2bjwav1r6j0xpk6-source/hosts/paperless-ngx/default.nix':
error: attribute 'CLOUDFLARE_DNS_API_TOKEN' missing
at /nix/store/iplskddnx91vv49mi2bjwav1r6j0xpk6-source/hosts/paperless-ngx/default.nix:69:25:
68|
69| environmentFile = config.sops.CLOUDFLARE_DNS_API_TOKEN.path;
70| };
Anyone know why this is happening and how I can fix this?
