An attribute set in a function definition can be bound to a variable via the @ syntax.
To my knowledge this should include all attributes (including omitted ones).
In nix repl this works fine:
test = { d, ... }: d
({ ... }@input: test input) { a = 1; d = 5; }
=> 5
Inside my NixOS configuration I’m trying to pass the input arguments on to a normal import statement:
lib,
config,
fn,
nvim-lazy,
pkgs,
}@inputs:
with lib;
imports = [
nvim-lazy.nixosModules.nvim-lazy
programs.nvim-lazy = mkIf (elem "nvim" config.machine.pkgs) {
lazyPlugins = flatten (
map (pluginPath: import pluginPath inputs) (
# this is just a helper function to list all files in a directory with absolute path
fn.lst {
path = (toString ./nvim);
fullPath = true;
This works only if I do not delete the “pkgs” line as it is otherwise not passed on to the files I’m importing, otherwise I’m getting the following error:
error: function 'anonymous lambda' called without required argument 'pkgs'
at /nix/store/k3wq6m7nr84ig2a82h09sf3sllxln8ys-source/pkgsets/nvim/fugitive.nix:1:1:
1| { pkgs, ... }:
2|
My best guess is that the ?module resolution? via imports = [ ] does some magic I’m not aware of so pkgs is never passed to the parent file unless it is explicitly requested.
Of course, I can always just manually map the required import arguments but it would be nice to just be able to pass everything down.
