I am building an sd_image for a raspberry pi and noticing a lot of unexpected output while running nix-build. For example I see building '/nix/store/59j9wz1zcib8i044xry5kqi4wfnxhrrn-xscreensaver.pam.drv
but I am building a headless/minimal setup.
I am wondering how I can list/output all of the packages that are being included in the final image. The official image from raspberry pi seems quite a bit smaller than the output produced from this build as well.
Here is a snipet of my setup:
build-sd.nix:
{ targetName }:
moduleArgs = {
_module.args = {
inherit targetName;
sandbox = false;
nixos-config = ./config/sd-image.nix;
evalutedConfig = (import <nixpkgs/nixos/lib/eval-config.nix> {
system = "aarch64-linux";
modules = [
moduleArgs
./sd-image.nix
evalutedConfig.config.system.build.sdImage
sd-image.nix
config,
pkgs,
lib,
targetName,
with lib;
imports = [
./configuration.nix
<nixpkgs/nixos/modules/installer/sd-card/sd-image-aarch64-installer.nix>
<nixpkgs/nixos/modules/profiles/minimal.nix>
targetName = mkOption {
default = "${targetName}";
description = lib.mdDoc ''
Name of the target
config = {
system.stateVersion = "23.11";
sdImage.compressImage = false;
And I’m evoking this with:
nix-build -I nixos-config=./config/configuration.nix --argstr targetName pi /config/config/build-sd.nix
