I’m on NixOS 23.11.5408.8ac30a39abc5 (Tapir)
I’m trying to build GitHub - kanoi/cgminer: ASIC/FPGA miner in c for bitcoin, which is an autotools
-based project.
Doing the following works:
# nix-shell -p autoconf-archive libtool autoconf automake autogen m4 pkg-config
$ ./autogen.sh
I want to make this permanent on my system, so I added the following autotools.nix
to my home-manager
setup:
{ config, pkgs, ... }: {
home.packages = with pkgs; [
automake
autogen
autoconf
autoconf-archive
libtool
pkg-config
m4
but when I try to run autogen.sh
, I get the following:
./autogen.sh
configure.ac:40: warning: The macro `AC_TRY_LINK' is obsolete.
configure.ac:40: You should run autoupdate.
./lib/autoconf/general.m4:2920: AC_TRY_LINK is expanded from...
configure.ac:40: the top level
configure.ac:52: warning: The macro `AC_TRY_LINK' is obsolete.
configure.ac:52: You should run autoupdate.
configure.ac:52: the top level
configure.ac:12: error: possibly undefined macro: AC_PROG_LIBTOOL
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
autoreconf: error: /nix/store/awlzx1g2fcq3n1ndwqrw0vc283mis9qy-autoconf-2.71/bin/autoconf failed with exit status: 1
googling for this error message renders suggestions to install libtool
, pkg-config
, autogen-archive
, all of which I already have installed via home-manager
What am I doing wrong?
