are there any best practices on how to create scripts using home-manager, when running home-manager on NixOS and non-NixOS systems?
I can of course just add an if-condition to the script to check whether it is on NixOS or not and then set the proper executable paths.
Or is it safe to just rely on the shell to find the proper executable depending on the PATH?
In my case I am using home-manager on Fedora Kinoite, where there is a “native” kdialog in /usr/bin/kdialog, while I need to use the one from the Nix store on NixOS.
If you never prefer to fall back to your base OS’ binary for something that is installed in both, you may like to use writeShellApplication to always get Nix binaries while still being able to write more concisely when authoring the scripts.
My main concern is that there are some things that get installed with home-manager/NixOS on one system but come from the base OS on another one.
I am not sure if it is a good idea to use e.g. kdialog from Nix on a Plasma desktop from Fedora. Not sure if there is some kind of version mismatch, so I would rather rely on the system one.
Hence my question how to best handle situations like these.
This seems like an “it depends” situation, where you’d have to make a choice whether you want to be self-contained and system independent (use writeShellApplication with all external exe’s the script refers to as package arguments) or use the system’s binaries.
I think (from your kdialog example), that if your script is specifically targeted at e.g. KDE, you could just rely on PATH and just use the executable’s names, since e.g. kdialog should be in it in your desktop session regardless Fedora or NixOS.
Probably the former method is more robust though, since normally I wouldn’t expect “version mismatches” on this level. What’s more, I’d even expect your nix’s kdialog to pickup your session theme etc., due to the way XDG... and DBUS etc. work. Of course this comes at the cost of increased dependencies for the script.
pkgs.resholve.writeScriptBin and builtins.readFile to read in the script mentioned in step 2. This way you are certain that all the required binaries are available on NixOS and the script will still work as normal on !NixOS.
Maybe I misunderstood your question, but the way I see it, you have two options:
if you have nix available where the script will run, use resholve to ensure all dependencies are in place. This means, if you call out to kdialog, it will be included at build time (not the one from the system environment).
if you don’t have nix, the script will run without having been processed by resholve and will just pick whatever it finds in PATH. Getting the script onto your target system is of course also something that needs to be handled outside.
Thanks Peter, that example is easy enough for me to get the grasp. The documentation for resholve is very large (and seems well written) but also kind of sophisticated. I was missing (or have overlooked) a simple example on how to use it.
And sorry if my question was too generic and the examples were a bit misleading. In most cases what you described would work, i.e. if I can just use the executable installed via nix because it does not have a strong relationship to system-related things.
Again, thanks for the answer and being patient with me…
