I’d like to fix the broken pyocr build on aarch64, but I’m on x86_64.
I’ll probably need a VM for this. Is there any existing infrastructure to simplify this task?
If you’re on NixOS, you can try something like this:
and then just build with:
nix build -f. python36Packages.pyocr --argstr system aarch64-linux
Woops, just posted from my laptop with an old account. Thanks, Matthew, that’s exactly what I needed!
I am trying to make use of this to build some haskell package targetting aarch64-linux. I am on a 'x86_64-linux' with features {kvm, nixos-test}.
This is also, what I get, when I run with the linked qemu.nix plus overlays folder checked out:
nix-build '<nixpkgs/nixos>' --argstr system aarch64-linux -A vm -I nixos-config=./qemu.nix -I nixpkgs=channel:nixos-19.09-small
So I am guessing, this is not how it is used.
Also, trying the vanilla command with the qemu.nix and overlays/qemu checked out doesn’t bring me further:
nix build -f qemu.nix python36Packages.pyocr --argstr system aarch64-linux
can you tell me how this works ?
EDIT: Will try this as a reference.
You can also look at the pkgsCross package set:
$ nix-build -A pkgsCross.
pkgsCross.aarch64-android-prebuilt pkgsCross.gnu32 pkgsCross.pogoplug4
pkgsCross.aarch64be-embedded pkgsCross.gnu64 pkgsCross.powernv
pkgsCross.aarch64-embedded pkgsCross.i686-embedded pkgsCross.ppc-embedded
pkgsCross.aarch64-multiplatform pkgsCross.iphone32 pkgsCross.ppcle-embedded
pkgsCross.aarch64-multiplatform-musl pkgsCross.iphone32-simulator pkgsCross.raspberryPi
pkgsCross.amd64-netbsd pkgsCross.iphone64 pkgsCross.riscv32
pkgsCross.arm-embedded pkgsCross.iphone64-simulator pkgsCross.riscv32-embedded
pkgsCross.armhf-embedded pkgsCross.mingw32 pkgsCross.riscv64
pkgsCross.armv7a-android-prebuilt pkgsCross.mingwW64 pkgsCross.riscv64-embedded
pkgsCross.armv7l-hf-multiplatform pkgsCross.msp430 pkgsCross.scaleway-c1
pkgsCross.avr pkgsCross.musl32 pkgsCross.sheevaplug
pkgsCross.ben-nanonote pkgsCross.musl64 pkgsCross.vc4
pkgsCross.fuloongminipc pkgsCross.muslpi pkgsCross.wasi32
pkgsCross.ghcjs pkgsCross.musl-power pkgsCross.x86_64-embedded
