Hi there, verrrry new nix user here.
Been slogging through nix-darwin setup the last few days. Emphasis on slog. But still excited.
I use a neat tool called llm to access llms via cli.
Happily I discovered that there was already a nixpkg created for it. Technically several. Which leads me to my first question. What is best practice for bringing in a nixpkg built from python? I see that there is a plain llm
and python311Packages.llm
. From what I can tell they point to the same derivation, so what is the difference?
Moving on…
llm
supports plugins for using various providers. I wanted to get it setup for using claude. Luckily the derivation author included a way to bring in plugins, woo!
BUT, there are no nixpkgs for the claude plugins (or anything others from what I can see). So I used this really great post to create the packages I needed with nix-init
I eventually got it working, here is my cfg, key part:
llm-claude = pkgs.python311Packages.callPackage ../packages/llm-claude/default.nix {
inherit (pkgs.python311Packages) anthropic;
llm-claude-3 = pkgs.python311Packages.callPackage ../packages/llm-claude-3/default.nix {
inherit llm-claude;
llmWithPlugins = pkgs.python311Packages.llm.withPlugins [ llm-claude-3 ];
but I am not particularly fond of how I had to do a two step process of creating two pkgs (llm-claude
and llm-claude-3
). I feel that I’m handling the dependencies in the wrong place - creating llm-claude
just to hand it off to llm-claude-3
. I think it should be possible to do it “lower level”. Such as in the llm-claude-3
Here is the definition of llm-claude-3. My main question: Is there a better way to do this??
Lastly, once I’ve got this cleaned up, I’d like to publish the nix derivation. Would that make sense?
Thanks for any assistance!
