Given a Nixified project, what’s the best way to create an augmented environment for specific dev tasks? I have some docs I want to generate and send with rsync. I don’t want to clutter the default.nix or shell.nix with a usually-unnecessary dependency on rsync, so I think I’d like to somehow create a nix-shell that includes both the package’s regular env, plus rsync. Ideally I could do this by passing args to nix-shell when using it as a script interpreter.
I suppose the question is, how do I create a dummy derivation that includes my package’s env as a buildInput, alongside other packages? With that, I could use the mechanism listed at the bottom of the section on Using nix-shell as a #! interpreter to get what I want.
Would it be enough to pass -p
to your nix-shell
invocation?
I’ll double check, but I doubt it, since -p is incompatible with specifying a file to evaluate. I.e., I think -p rsync will cause shell.nix to be ignored. I’ll update this if I’m wrong.
If that’s the case, it’s not well documented at all. man nix-shell
doesn’t at all suggest that -p
overrides a shell.nix
I double checked, and -p does, in fact, ignore shell.nix.
The man page does suggest this, somewhat abstractly. The synopsis says
nix-shell ... {[--packages | -p]packages | [path]}
which shows you can either specify packages, or specify a path to a nix file. It just happens that specifying a path is the default, with shell.nix
and default.nix
the defaults to the default.
mkShell
is like stdenv.mkDerivationto
dedicated for shell.nix. It adds one more feature where multiple package build inputs can all be merged together. This is useful when developing in a repo that has multiple packages (micro-services).
shell.nix
let pkgs = import <nixpkgs> {};
pkgs.mkShell {
# this adds all the build inputs of your project package
inputsFrom = [ (import ./default.nix { inherit pkgs; };) ];
# now add your other dependencies
buildInputs = with pkgs; [ rsync ];
