I have the following definition in my systemPackages, which gives me an fhs binary which drops me into a shell which looks like a normal Linux:
(pkgs.buildFHSUserEnv {
name = "fhs";
targetPkgs = pkgs: with pkgs; [
alsa-lib atk cairo cups curl dbus expat file fish fontconfig freetype
fuse glib gtk3 libGL libnotify libxml2 libxslt netcat nspr nss openjdk8
openssl.dev pango pkg-config strace udev vulkan-loader watch wget which
xorg.libX11 xorg.libxcb xorg.libXcomposite xorg.libXcursor
xorg.libXdamage xorg.libXext xorg.libXfixes xorg.libXi xorg.libXrandr
xorg.libXrender xorg.libXScrnSaver xorg.libxshmfence xorg.libXtst
xorg.xcbutilkeysyms zlib fontconfig.lib
profile = ''export FHS=1'';
runScript = "fish";
# all of my other packages
$ ls /usr/lib
"/usr/lib": No such file or directory (os error 2)
$ fhs
(fhs) $ ls /usr/lib | head -n 5
dr-xr-xr-x - nobody 1 Jan 1970 32
dr-xr-xr-x - nobody 1 Jan 1970 audit
dr-xr-xr-x - nobody 1 Jan 1970 bash
dr-xr-xr-x - nobody 1 Jan 1970 cairo
lrwxrwxrwx 69 nobody 1 Jan 1970 crt1.o -> /nix/store/aji28kaprqnrkapmfyjnnnv3ffvlaq0a-fhs-usr-target/lib/crt1.o
(fhs) $ # I can now run various unpatched vanilla binaries here
It works great, except that there’s this frightening block of standard packages which I partially copied from somewhere, and partially append a bunch of random stuff myself.
Is there some maintained-by-someone-else package I can re-use here? I am essentially looking for buildFHSUserEnv specialized to a set of “standard” packages (whatever that set is at the current moment in time).
I’m not aware of any standard set of packages, but something like this can include most of what you want
builtins.concatMap (p: p.buildInputs) config.environment.systemPackages
I’m not super familiar with it, but I think there are various lists of packages for use with buildfhsuserenvs in nixpkgs.
For instance:
Used here for example (I think):
Thanks, this is exactly what I was looking for!
I wanted to share this little script:
nix shell --impure --expr '(builtins.getFlake "nixpkgs-current").legacyPackages.${builtins.currentSystem}.buildFHSUserEnv { name = "fhs"; targetPkgs = p: with p; ['"$*"' ]; }' --command fhs
Arguments accepted are simply packages. This can also be improved to include support for additional arguments to the shell itself etc…
Thank you so much for this solution, it’s been a huge help in setting up a development shell with Nix flakes.
If this can help someone else, here’s how I’ve used it in flake.nix:
description = ".NET development environment based on the Filesystem Hierarchy Standard (FHS)";
# https://en.wikipedia.org/wiki/Filesystem_Hierarchy_Standard
nixpkgs.url = "github:nixos/nixpkgs?ref=nixos-unstable";
outputs = { nixpkgs, ... } @ inputs:
system = "x86_64-linux";
# .NET SDKs
dotnet_sdk = (with pkgs.dotnetCorePackages; combinePackages [
# Install all the .NET SDK versions needed here...
# sdk_8_0
# sdk_7_0
sdk_6_0
# Create development shell based on the Filesystem Hierarchy Standard (FHS) with a set of
# standard packages based on the list maintained by the appimagetools package
# buildFHSEnv -> https://nixos.org/manual/nixpkgs/stable/#sec-fhs-environments
# The packages included in appimagetools.defaultFhsEnvArgs are:
# https://github.com/NixOS/nixpkgs/blob/fd6a510ec7e84ccd7f38c2ad9a55a18bf076f738/pkgs/build-support/appimage/default.nix#L72-L208
devShells.${system}.default = (pkgs.buildFHSEnv (pkgs.appimageTools.defaultFhsEnvArgs // {
name = "dotnet-development-environment";
# Packages installed in the development shell
# .NET SDK
dotnet_sdk
# Run PowerShell scripts, which are sometimes included in NuGet packages like Playwright
powershell
# Timezones
tzdata
# Locales
glibcLocales
# Commands to be executed in the development shell
profile = ''
# Ensure that dotnet tools can find the .NET location
export DOTNET_ROOT="${dotnet_sdk}";
# Set LANG for locales, otherwise it is unset when running "nix-shell --pure"
export LANG="C.UTF-8"
# Remove duplicate commands from Bash shell command history
export HISTCONTROL=ignoreboth:erasedups
# Do not pollute $HOME with config files (both paths are ignored in .gitignore)
export DOTNET_CLI_HOME="$PWD/.net_cli_home";
export NUGET_PACKAGES="$PWD/.nuget_packages";
# Put dotnet tools in $PATH to be able to use them
export PATH="$DOTNET_CLI_HOME/.dotnet/tools:$PATH"
})).env;
