brnix
December 23, 2023, 3:20am
1
Hi there,
I have been using something like the following when I install a prebuilt binary from GitHub Releases.
{ lib, pkgs, ... }:
# https://github.com/dagger/dagger/releases
let version = "0.9.5";
in pkgs.stdenv.mkDerivation {
name = "dagger";
dontConfigue = true;
src = pkgs.fetchzip {
url =
"https://github.com/dagger/dagger/releases/download/v${version}/dagger_v${version}_linux_amd64.tar.gz";
sha256 = "sha256-RipH7gy9IL/xRlZy+KHIz8WfK1vrRUOdmY0G/rbc19c=";
stripRoot = true;
phases = [ "installPhase" ];
installPhase = ''
mkdir -p $out/bin
cp -r $src $out/bin/dagger
chmod +x $out/bin/dagger
meta = with lib; {
description = "dagger - https://docs.dagger.io/.";
maintainers = [ bashfulrobot ];
Now, one of the things I always seem to have to muck around with, is figuring out what ends up in $src (structure wise), where the binary is, so I know how to copy it out into $out/bin.
My current process is to get it working to a point, and then use find in the results and adjust as needed. It feels wrong (likely is), and I assume there has to be a better way.
How are others doing this?
Thank you.
rvl
December 23, 2023, 3:44am
2
To get the result of fetchzip, you can use:
$ nix-build '<nixpkgs>' -A pkgs.hello.src
$ readlink ./result
(I am using the hello package as the example. Adjust your commands accordingly.)
But you would like to know $src, or $sourceRoot:
/tmp/test $ nix-shell '<nixpkgs>' -A pkgs.hello
[nix-shell:/tmp/test]$ echo $out
/nix/store/zhl06z4lrfrkw5rp0hnjjfrgsclzvxpm-hello-2.12.1
[nix-shell:/tmp/test]$ echo $src
/nix/store/pa10z4ngm0g83kx9mssrqzz30s84vq7k-hello-2.12.1.tar.gz
[nix-shell:/tmp/test]$ unpackPhase
unpacking source archive /nix/store/pa10z4ngm0g83kx9mssrqzz30s84vq7k-hello-2.12.1.tar.gz
source root is hello-2.12.1
setting SOURCE_DATE_EPOCH to timestamp 1653865426 of file hello-2.12.1/ChangeLog
[nix-shell:/tmp/test]$ find $sourceRoot | head
hello-2.12.1
hello-2.12.1/build-aux
hello-2.12.1/build-aux/missing
hello-2.12.1/build-aux/gnupload
hello-2.12.1/build-aux/prefix-gnulib-mk
hello-2.12.1/build-aux/compile
hello-2.12.1/build-aux/texinfo.tex
hello-2.12.1/build-aux/config.rpath
hello-2.12.1/build-aux/useless-if-before-free
hello-2.12.1/build-aux/gnu-web-doc-update
HTH
brnix
January 15, 2024, 6:12pm
3
Thank you so much!
Yeah, that definitely will help me in the future. Currently my process had been a little bit of trial and air.
