Better way to use nixpkgs git repo
Hello! I have a question about better usage of nixpkgs github repo. For example I want to use this expression
Atm I have nixpkgs as submodule in git repo of my library. So far it was ok to have it, but I found that if I’m using my library in other haskell stack project (as extra-dep), stack build tool tries to fetch all library submodules with the command
git submodule update --init --recursive
Which is ok, but not for this huge repo. And I don’t see possibility to say stack to add --depth 1 parameter or something like that. So maybe there are better ways to use nixpkgs than just git submodule in project? Thanks!
i think what you are trying to accomplish can be done like so:
src = fetchgit {
    url = "https://github.com/your_repo/with_submodules.git";
    rev = "...";
    sha256 = "...";
    deepClone = false;
    fetchSubmodules = false;
Haskell stack don’t understand nix expressions. In my case it has library with submodules in stack.yaml
extra-deps:
       - github: organization/package
         commit: ...
where organization/package has nixpkgs as submodule. I’m thinking how to avoid usage of nixpkgs submodule, because tools like haskell stack are doing only deep clone.
I’m just thinking that my approach to have access to nixpkgs expressions through git submodule might be wrong. I’m just not aware of alternatives.
Using builtins.fetchTarball you can avoid git cloning nixpkgs.git. Create a nixpkgs.nix containing this for instance:
builtins.fetchTarball {url="https://github.com/NixOS/nixpkgs-channels/archive/b7bdf48e3fa6b90ea475a03ed159f397bd3c3c65.tar.gz"; sha256="0ap49yync5rwvr5qn0qb45x2yzzix2vhfqfljbampdhs0ncnhigi";}
and use it in a shell.nix like this:
  nixpkgs = import ./nixpkgs.nix;
  pkgs = import nixpkgs {};
pkgs.mkShell {
  buildInputs = [
    pkgs.stack
  shellHook = ''
    export NIX_PATH="nixpkgs=${nixpkgs}"
You can generate this nixpkgs.nix like that (eg. in a .envrc when nixpkgs.nix does not exist):
nixpkgs_channel=nixos-unstable-small
rev=$(curl -L https://nixos.org/channels/"$nixpkgs_channel"/git-revision | head -n1 | tr -dC 'a-z0-9')             sha256=$(nix-prefetch-url --unpack https://github.com/NixOS/nixpkgs-channels/archive/"$rev".tar.gz)
echo >nixpkgs.nix "builtins.fetchTarball {url=\"https://github.com/NixOS/nixpkgs-channels/archive/$rev.tar.gz\"; sha256=\"$sha256\";}"
If you need to patch nixpkgs (when overlays are not powerful enough, eg. to change the type of an option of a NixOS service, or to directly fetch a PR which is not merged yet), you can do like this:
  originNixpkgs = import ./nixpkgs.nix;
  originPkgs = import originNixpkgs {};
  nixpkgsPatches = [
    { meta.description = "Dovecot plugin for Full Text Search (FTS) with Xapian";
      url = "https://github.com/NixOS/nixpkgs/pull/78780.diff";
      sha256 = "053md69ryybj27cp0xdfrza48zyzpblk6wvb2m2dbs9hm0gmcwc4";
    { meta.description = "dstat: fix pluginpath";
      url = "https://github.com/NixOS/nixpkgs/pull/80151.diff";
      sha256 = "0jjw2gvp7b7v2n2m2d6yj0gw711j6p9lyjf5ywp2y9ql6905qf4b";
  localNixpkgsPatches = [
    #patches/direnv.diff
  nixpkgs = originPkgs.stdenv.mkDerivation {
    name = "nixpkgs-patched";
    src = originNixpkgs;
    phases = [ "unpackPhase" "patchPhase" ];
    patches = map originPkgs.fetchpatch nixpkgsPatches ++ localNixpkgsPatches;
    postPatch = ''
      patch=$(printf '%s\n' ${builtins.concatStringsSep " " (map (p: p.sha256) nixpkgsPatches)} |
        sort | sha256sum | cut -c -7)
      mv $PWD $out
      echo "+patch-$patch" >$out/.version-suffix
    config = {}; # Make the config pure, ignoring user's config.
    #overlays = import ./overlays.nix;
HTH,
Julien
Thanks! But it’s still unclear for me how exactly I can access this expression
Now when I have submodule, I’m just using
import ./nixpkgs/pkgs/development/beam-modules/build-mix.nix {
               inherit stdenv writeText elixir erlang hex lib;
Importing yourself a path from within nixpkgs is rarely needed, I guess here you could use pkgs.beamPackages.hex.
Should you want to do such a contrived import, here is how you can:
nix-instantiate --eval --expr 'let nixpkgs = import ./nixpkgs.nix; pkgs = import nixpkgs {}; hex = pkgs.callPackage (nixpkgs + "/pkgs/development/beam-modules/hex") {}; in hex'
Or using the nixpkgs in your $NIX_PATH:
nix-instantiate --eval --expr 'let pkgs = import <nixpkgs> {}; hex = pkgs.callPackage <nixpkgs/pkgs/development/beam-modules/hex> {}; in hex'
Here, using pkgs.callPackage is like your import but avoids the manual inherit by auto-supplying attributes using those in pkgs.
You can override those using the extra {} if need be.
Wow, that implicit inherit looks cool, I’ll definitely try it out, thanks!
