I’m in a nix-shell
that is running zsh
(thanks for zsh-nix-shell
). Then I tried running bash
, and this happened:
❯ bash
bind: command not found
\[\][\[\]trusktr@laptop:~/src/test]$\[\] exit
Any ideas why this may possibly be? The command line also seems to be escaped.
Hmmm, I discovered that it only happens if I’m already in a nix-shell. For example:
❯ nix-shell -p ~/src/trusktr+nixpkgs/result
❯ nix run ~/src/trusktr+nixpkgs/result
\[\][\[\]trusktr@starnix:~/src/test]$\[\]
I also have this issue where bash appears to have no bind
builtin. I’m using macOS Monterey and wanted to install the latest bash version. Which appears to be working fine, but keys are not bound to anything.
Installed via:
nix-env -i bash
add bash
to /etc/shells
(/Users/red/.nix-profile/bin/bash
and change with chsh
chsh -s /Users/red/.nix-profile/bin/bash
this works… basically… but bind
is missing.
Maybe I need to add something?
I reverted back to zsh (chsh -s /bin/zsh
) and when I launch bash
from there it presents the same problem:
red@Arkani ~ % which bash
red@Arkani ~ % bash -version
GNU bash, version 5.1.8(1)-release (x86_64-apple-darwin17.7.0)
Copyright (C) 2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software; you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
red@Arkani ~ % bash
Arkani:~ red$ bind
bash: bind: command not found
Edit: The default bash (v3.2) works:
red@Arkani ~ % /bin/bash
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
bash-3.2$ type bind
bind is a shell builtin
bash-3.2$ bind -h
bash: bind: -h: invalid option
bind: usage: bind [-lpvsPVS] [-m keymap] [-f filename] [-q name] [-u name] [-r keyseq] [-x keyseq:shell-command] [keyseq:readline-function or readline-command]
I imagine you’re using the bash
attr, and want bashInteractive
for a user shell
Oh TIL there is bashInteractive. Running nix-env -i bash-interactive
seems to instantly solve my problem. Thanks a lot!
