I am creating a NixOS module to run a service obtained from a Docker image in a systemd-nspawn container.
The general idea is:
- Pull the image using
pkgs.dockerTools.pullImage
- Export that image to a tarball with
pkgs.dockerTools.exportImage
- Extract that tarball into the Nix store with a simple invocation of
pkgs.runCommand
- Bind mount the extracted tree into
/var/lib/machines/<service-name>
- Create the appropriate
<service-name>.nspawn
file - Enable the relevant
systemd-nspawn@<service-name>.service
As an example of what I’m thinking of, here’s my attempt at endlessh.nix
{ config, pkgs, lib, ... }:
cfg = config.containerServices.endlessh;
endlesshImage = pkgs.dockerTools.exportImage {
fromImage = pkgs.dockerTools.pullImage {
imageName = "ghcr.io/linuxserver/endlessh";
imageDigest = "sha256:1a80087704a1fffb750b5a07ef296d2ff21f8524d4d206d896cad521096c8a75";
finalImageTag = "dfe44eb2-ls72";
sha256 = ""; # will handle this once things are working
endlesshTree = pkgs.runCommand {
name = "endlessh";
buildCommand = ''
mkdir "$out"
tar --directory="$out" --extract --file="${endlesshImage}"
options = {
containerServices.endlessh = {
enable = lib.mkEnableOption (lib.mdDoc "Endlessh is an SSH tarpit that very slowly sends an endless, random SSH banner.");
config = lib.mkIf cfg.enable {
fileSystems."/var/lib/machines/endlessh" = {
device = "${endlesshTree}";
options = [ "bind" ];
systemd.nspawn.endlessh = {
execConfig = { /*snip*/ };
filesConfig = { /*snip*/ };
networkConfig = { /*snip*/ };
systemd.services."systemd-nspawn@endlessh.service".enable = true;
It would be used in configuration.nix
like:
imports = [ ./endlessh.nix ];
containerServices.endlessh.enable = true;
This unfortunately doesn’t work: nixos-rebuild build
fails with the error cannot coerce a function to a string
in the definition of the device
for the bind mount. I have tried "${endlesshTree}"
, applying "${builtins.path endlesshTree}"
, and also changing to pkgs.callPackage pkgs.runCommand ...
to no avail.
This leaves me with a few questions:
- How can I get the output path of the
runCommand
invocation in my configuration? Is a bind mount even the best way to make part of the Nix store available under/var
? - Would it be possible to refactor this so, for example, the image tag/digest could be overridden with an option like
containerServices.endlessh.imageDigest = "..."
? In its current form it seems like this would be difficult since it would be affecting things that were evaluated above it. (This is in trying to be analogous to the commonservices.<name>.package
option.) - Is this approach overall sound, or is there a better way to get an unpacked Docker image into the store? (Is this an Import From Derivation in a bad way?)
- Finally, an optimization question: if my understanding is correct, the Docker image will be present in the store 3 times: once in whatever form
pullImage
gets it, once in the tarball fromexportImage
, and once after being unpacked. Is there a reasonable way to avoid this without having to fully reimplement parts ofdockerTools
Thanks for your help!
