As I can’t find how to make my microphone working, following Speakers, microphone, camera not detected on new Dell XPS-9320 - Support - Manjaro Linux Forum I realized that my sound card accepts multiple drivers
$ inxi -Fazy
Audio:
Device-1: Intel Alder Lake Imaging Signal Processor vendor: Dell
driver: intel-ipu6 alternate: intel_ipu6,intel_ipu6_psys,intel_ipu6_isys
bus-ID: 00:05.0 chip-ID: 8086:465d class-ID: 0480
Device-2: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Sound Server-1: ALSA v: k6.1.80 running: yes
Sound Server-2: PipeWire v: 1.0.1 running: yes
and someone reported success with the snd_hda_intel module. So I tried to put:
boot.initrd.availableKernelModules = [ "xhci_pci" "thunderbolt" "nvme" ];
boot.initrd.kernelModules = [];
boot.kernelModules = [ "snd_hda_intel" "kvm-intel" ];
boot.blacklistedKernelModules = [ "psmouse" "sof-audio-pci-intel-tgl" "sof_audio_pci_intel_tgl" ]; # used in nixos-hardware for similar devices inxi -Fazy
boot.extraModulePackages = [];
Unfortunately, after a reboot sof-audio-pci-intel-tgl is still loaded. Why isn’t my blacklist applied? How can I force the other driver?
Here is my dmesg:
$ dmesg | egrep "(snd|audio)" -C 4
[ 8.864690] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 8.877721] ACPI: bus type drm_connector registered
[ 8.884362] systemd[1]: Finished Load Kernel Module configfs.
[ 8.884788] systemd[1]: Started Journal Service.
[ 8.893686] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 8.893760] snd_hda_intel 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[ 8.977228] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 8.982554] tun: Universal TUN/TAP device driver, 1.6
[ 8.986893] loop: module loaded
[ 8.990861] mc: Linux media interface: v0.10
[ 9.506039] Bluetooth: hci0: Firmware Version: 60-48.23
[ 9.507217] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[ 9.507428] intel_tcc_cooling: Programmable TCC Offset detected
[ 9.509011] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 9.515358] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 9.515437] sof-audio-pci-intel-tgl 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[ 9.515449] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 9.515697] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 9.515950] intel vsc not ready
[ 9.533353] intel vsc not ready
[ 9.554166] intel vsc not ready
[ 9.558325] intel vsc not ready
[ 11.307725] NET: Registered PF_ALG protocol family
[ 11.423827] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 11.426562] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 11.427507] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input15
[ 11.427678] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 11.428373] intel vsc not ready
[ 11.429065] intel vsc not ready
[ 11.436279] fbcon: i915drmfb (fb0) is primary device
[ 11.453534] Console: switching to colour frame buffer device 240x75
[ 11.473326] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 11.492441] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 11.502944] intel vsc not ready
[ 11.503452] intel vsc not ready
[ 11.508108] intel vsc not ready
[ 11.509219] intel vsc not ready
[ 11.509897] intel vsc not ready
[ 11.512820] intel vsc not ready
[ 11.513198] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 4
[ 11.530254] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 11.530258] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 11.530264] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 11.645027] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 11.645031] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 11.652647] rt1316-sdca sdw:1:025d:1316:01: Bus clash detected before INT mask is enabled
[ 11.652771] rt1316-sdca sdw:2:025d:1316:01: Bus clash detected before INT mask is enabled
[ 11.653027] rt715-sdca sdw:0:025d:0714:01: Bus clash detected before INT mask is enabled
[ 11.677536] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
[ 11.677633] sof_sdw sof_sdw: ASoC: Parent card not yet available, widget card binding deferred
[ 11.692650] sof_sdw sof_sdw: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 11.711904] input: sof-soundwire HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/sof_sdw/sound/card0/input16
[ 11.711950] input: sof-soundwire HDMI/DP,pcm=6 as /devices/pci0000:00/0000:00:1f.3/sof_sdw/sound/card0/input17
lsmod:
[leo@bestos:~]$ lsmod
Module Size Used by
ccm 20480 6
qrtr 49152 4
rfcomm 94208 16
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 90112 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
snd_ctl_led 24576 0
snd_soc_sof_sdw 65536 9
snd_soc_intel_hda_dsp_common 20480 1 snd_soc_sof_sdw
snd_sof_probes 24576 0
snd_soc_intel_sof_maxim_common 20480 1 snd_soc_sof_sdw
snd_hda_codec_hdmi 81920 1
snd_soc_rt715_sdca 40960 1
snd_soc_rt1316_sdw 28672 2
regmap_sdw_mbq 16384 1 snd_soc_rt715_sdca
regmap_sdw 16384 2 snd_soc_rt715_sdca,snd_soc_rt1316_sdw
cmac 16384 3
algif_hash 16384 1
algif_skcipher 16384 1
af_alg 32768 6 algif_hash,algif_skcipher
af_packet 57344 6
bnep 24576 2
hid_sensor_custom_intel_hinge 16384 0
hid_sensor_als 20480 0
hid_sensor_trigger 20480 4 hid_sensor_custom_intel_hinge,hid_sensor_als
industrialio_triggered_buffer 16384 1 hid_sensor_trigger
kfifo_buf 16384 1 industrialio_triggered_buffer
hid_sensor_iio_common 20480 3 hid_sensor_trigger,hid_sensor_custom_intel_hinge,hid_sensor_als
industrialio 110592 5 industrialio_triggered_buffer,hid_sensor_trigger,hid_sensor_custom_intel_hinge,kfifo_buf,hid_sensor_als
hid_sensor_custom 28672 0
msr 16384 0
hid_sensor_hub 24576 5 hid_sensor_trigger,hid_sensor_iio_common,hid_sensor_custom_intel_hinge,hid_sensor_als,hid_sensor_custom
intel_ishtp_hid 28672 0
joydev 28672 0
mousedev 24576 0
nls_iso8859_1 16384 1
nls_cp437 20480 1
vfat 24576 1
fat 90112 1 vfat
hid_multitouch 32768 0
spi_pxa2xx_platform 36864 0
hid_generic 16384 0
dw_dmac 16384 0
dw_dmac_core 36864 1 dw_dmac
8250_dw 24576 0
iwlmvm 442368 0
i915 3047424 18
intel_ipu6_isys 135168 0
snd_soc_dmic 16384 0
snd_sof_pci_intel_tgl 16384 10
mac80211 1093632 1 iwlmvm
snd_sof_intel_hda_common 188416 1 snd_sof_pci_intel_tgl
intel_tcc_cooling 16384 0
snd_soc_hdac_hda 24576 1 snd_sof_intel_hda_common
soundwire_intel 49152 4 snd_sof_intel_hda_common
soundwire_generic_allocation 16384 1 soundwire_intel
soundwire_cadence 36864 1 soundwire_intel
snd_sof_intel_hda 20480 1 snd_sof_intel_hda_common
x86_pkg_temp_thermal 20480 0
intel_powerclamp 20480 0
snd_sof_pci 24576 2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_sof_xtensa_dsp 16384 1 snd_sof_intel_hda_common
snd_sof 270336 3 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_probes
videobuf2_dma_contig 20480 1 intel_ipu6_isys
videobuf2_memops 20480 1 videobuf2_dma_contig
coretemp 20480 0
videobuf2_v4l2 36864 1 intel_ipu6_isys
drm_buddy 20480 1 i915
crc32_pclmul 16384 0
polyval_clmulni 16384 0
ttm 90112 1 i915
videobuf2_common 65536 4 videobuf2_dma_contig,videobuf2_v4l2,intel_ipu6_isys,videobuf2_memops
polyval_generic 16384 1 polyval_clmulni
gf128mul 16384 1 polyval_generic
snd_sof_utils 20480 1 snd_sof
ghash_clmulni_intel 16384 0
sha512_ssse3 49152 0
sha512_generic 16384 1 sha512_ssse3
sha256_ssse3 36864 0
sha1_ssse3 32768 0
snd_hda_ext_core 36864 2 snd_sof_intel_hda_common,snd_soc_hdac_hda
cmdlinepart 16384 0
libarc4 16384 1 mac80211
aesni_intel 393216 8
drm_display_helper 172032 1 i915
spi_nor 114688 0
btusb 69632 0
dell_laptop 32768 0
intel_ipu6_psys 98304 0
snd_soc_acpi_intel_match 77824 2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
crypto_simd 16384 1 aesni_intel
dell_wmi 20480 0
ledtrig_audio 16384 2 snd_ctl_led,dell_laptop
ext4 958464 1
cryptd 24576 3 crypto_simd,ghash_clmulni_intel
snd_soc_acpi 16384 2 snd_soc_acpi_intel_match,snd_sof_intel_hda_common
ov01a10 28672 1
mtd 86016 3 spi_nor,cmdlinepart
btrtl 28672 1 btusb
cec 61440 1 i915
dell_smbios 32768 2 dell_wmi,dell_laptop
iTCO_wdt 16384 0
soundwire_bus 98304 8 snd_soc_sof_sdw,snd_soc_rt715_sdca,regmap_sdw,snd_soc_rt1316_sdw,regmap_sdw_mbq,soundwire_intel,soundwire_generic_allocation,soundwire_cadence
rapl 16384 0
dcdbas 20480 1 dell_smbios
btbcm 24576 1 btusb
intel_pmc_bxt 16384 1 iTCO_wdt
mei_csi 16384 0
drm_kms_helper 192512 2 drm_display_helper,i915
btintel 45056 1 btusb
dell_wmi_sysman 53248 0
mbcache 16384 1 ext4
mei_hdcp 24576 0
mei_pxp 20480 0
firmware_attributes_class 16384 1 dell_wmi_sysman
spi_ljca 20480 0
watchdog 32768 1 iTCO_wdt
btmtk 16384 1 btusb
processor_thermal_device_pci 16384 0
intel_cstate 20480 0
iwlwifi 462848 1 iwlmvm
gpio_ljca 20480 2
i2c_ljca 20480 0
jbd2 163840 1 ext4
intel_rapl_msr 20480 0
intel_gtt 24576 1 i915
dell_wmi_descriptor 20480 2 dell_wmi,dell_smbios
wmi_bmof 16384 0
mei_ace 16384 0
processor_thermal_device 20480 1 processor_thermal_device_pci
snd_soc_core 352256 10 snd_soc_sof_sdw,snd_soc_rt715_sdca,snd_soc_rt1316_sdw,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_intel_sof_maxim_common,snd_sof_probes,snd_soc_dmic
intel_uncore 217088 0
processor_thermal_rfim 16384 1 processor_thermal_device
agpgart 45056 2 intel_gtt,ttm
intel_ish_ipc 28672 0
i2c_hid_acpi 16384 0
bluetooth 913408 44 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
intel_ishtp 61440 2 intel_ishtp_hid,intel_ish_ipc
snd_compress 28672 2 snd_soc_core,snd_sof_probes
i2c_hid 32768 1 i2c_hid_acpi
intel_vsc 16384 3 mei_ace,mei_csi,ov01a10
processor_thermal_mbox 16384 2 processor_thermal_rfim,processor_thermal_device
i2c_algo_bit 16384 1 i915
tpm_crb 24576 0
ac97_bus 16384 1 snd_soc_core
video 65536 3 dell_wmi,dell_laptop,i915
spi_intel_pci 16384 0
ucsi_acpi 16384 0
ecdh_generic 16384 2 bluetooth
intel_lpss_pci 28672 2
cfg80211 1130496 3 iwlmvm,iwlwifi,mac80211
intel_ipu6 106496 2 intel_ipu6_isys,intel_ipu6_psys
mei_vsc 45056 2
spi_intel 28672 1 spi_intel_pci
typec_ucsi 53248 1 ucsi_acpi
intel_skl_int3472_tps68470 20480 0
igen6_edac 24576 0
i2c_i801 36864 0
mei_me 53248 2
tiny_power_button 16384 0
ecc 40960 1 ecdh_generic
intel_lpss 16384 1 intel_lpss_pci
processor_thermal_rapl 20480 1 processor_thermal_device
crc16 16384 2 bluetooth,ext4
fb_sys_fops 16384 1 drm_kms_helper
v4l2_fwnode 32768 2 ov01a10,intel_ipu6_isys
typec 86016 1 typec_ucsi
ljca 32768 3 gpio_ljca,i2c_ljca,spi_ljca
idma64 20480 0
snd_pcm_dmaengine 16384 1 snd_soc_core
syscopyarea 16384 1 drm_kms_helper
i2c_smbus 20480 1 i2c_i801
tps68470_regulator 16384 0
intel_rapl_common 28672 2 intel_rapl_msr,processor_thermal_rapl
tpm_tis 16384 0
libaes 16384 2 bluetooth,aesni_intel
8250_pci 65536 0
virt_dma 20480 1 idma64
sysfillrect 16384 1 drm_kms_helper
int3403_thermal 20480 0
clk_tps68470 16384 0
rfkill 28672 9 iwlmvm,bluetooth,dell_laptop,cfg80211
edac_core 69632 1 igen6_edac
sysimgblt 16384 1 drm_kms_helper
roles 16384 1 typec_ucsi
tpm_tis_core 32768 1 tpm_tis
battery 28672 0
button 24576 0
hid 155648 5 i2c_hid,hid_multitouch,hid_sensor_hub,intel_ishtp_hid,hid_generic
mei 159744 10 mei_ace,mei_csi,mei_hdcp,mei_pxp,mei_vsc,mei_me
v4l2_async 28672 3 v4l2_fwnode,ov01a10,intel_ipu6_isys
int340x_thermal_zone 20480 2 int3403_thermal,processor_thermal_device
wmi 36864 6 dell_wmi_sysman,video,dell_wmi,wmi_bmof,dell_smbios,dell_wmi_descriptor
int3400_thermal 20480 0
intel_pmc_core 53248 0
intel_skl_int3472_discrete 16384 0
intel_hid 28672 0
pinctrl_tigerlake 32768 3
acpi_thermal_rel 16384 1 int3400_thermal
sparse_keymap 16384 2 intel_hid,dell_wmi
acpi_tad 20480 0
acpi_pad 28672 0
evdev 28672 15
ac 20480 0
input_leds 16384 0
led_class 20480 3 input_leds,iwlmvm,dell_laptop
ip6_tables 36864 2
mac_hid 16384 0
serio_raw 20480 0
xt_conntrack 16384 2
nf_conntrack 172032 1 xt_conntrack
nf_defrag_ipv6 24576 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
ip6t_rpfilter 16384 1
ipt_rpfilter 16384 1
xt_pkttype 16384 2
xt_LOG 20480 2
nf_log_syslog 24576 2
xt_tcpudp 20480 0
nft_compat 20480 11
nf_tables 303104 113 nft_compat
libcrc32c 16384 2 nf_conntrack,nf_tables
crc32c_generic 16384 0
nfnetlink 20480 2 nft_compat,nf_tables
sch_fq_codel 20480 1
ctr 16384 2
v4l2loopback 57344 1
videodev 282624 7 v4l2_async,videobuf2_v4l2,ov01a10,v4l2loopback,intel_ipu6_isys,videobuf2_common
mc 73728 6 v4l2_async,videodev,videobuf2_v4l2,ov01a10,intel_ipu6_isys,videobuf2_common
loop 32768 0
cpufreq_powersave 20480 0
tun 61440 0
tap 28672 0
macvlan 28672 0
bridge 311296 0
stp 16384 1 bridge
llc 16384 2 bridge,stp
kvm_intel 380928 0
kvm 1118208 1 kvm_intel
irqbypass 16384 1 kvm
snd_hda_intel 57344 0
snd_intel_dspcfg 36864 3 snd_hda_intel,snd_sof,snd_sof_intel_hda_common
snd_intel_sdw_acpi 20480 2 snd_sof_intel_hda_common,snd_intel_dspcfg
snd_hda_codec 176128 5 snd_hda_codec_hdmi,snd_hda_intel,snd_soc_intel_hda_dsp_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_hda_core 118784 8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_intel_hda_dsp_common,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 155648 18 snd_soc_rt715_sdca,snd_hda_codec_hdmi,snd_soc_rt1316_sdw,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_soc_core,snd_sof_utils,snd_hda_core,snd_pcm_dmaengine
drm 581632 13 drm_kms_helper,drm_display_helper,drm_buddy,i915,ttm
snd_timer 49152 3 snd_seq,snd_hrtimer,snd_pcm
snd 118784 28 snd_ctl_led,snd_soc_sof_sdw,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_pcm
soundcore 16384 2 snd_ctl_led,snd
fuse 155648 5
deflate 16384 1
backlight 24576 5 video,drm_display_helper,dell_laptop,i915,drm
configfs 57344 1
efi_pstore 16384 0
efivarfs 24576 1
tpm 94208 3 tpm_tis,tpm_crb,tpm_tis_core
rng_core 20480 1 tpm
dmi_sysfs 20480 0
ip_tables 36864 1
x_tables 53248 9 xt_conntrack,ip6t_rpfilter,nft_compat,xt_LOG,xt_tcpudp,ip6_tables,ipt_rpfilter,xt_pkttype,ip_tables
autofs4 53248 0
xhci_pci 24576 0
xhci_pci_renesas 20480 1 xhci_pci
firmware_class 49152 17 btrtl,snd_hda_intel,intel_ipu6,xhci_pci_renesas,btmtk,snd_sof,drm_display_helper,mei_vsc,intel_ipu6_isys,btintel,btbcm,iwlwifi,btusb,i915,intel_ipu6_psys,cfg80211,drm
xhci_hcd 315392 1 xhci_pci
nvme 53248 3
nvme_core 151552 4 nvme
atkbd 36864 0
usbcore 339968 4 xhci_hcd,ljca,btusb,xhci_pci
libps2 20480 1 atkbd
thunderbolt 376832 0
vivaldi_fmap 16384 1 atkbd
t10_pi 16384 1 nvme_core
crc64_rocksoft 20480 1 t10_pi
crc64 20480 1 crc64_rocksoft
crc_t10dif 20480 1 t10_pi
crct10dif_generic 16384 0
crc32c_intel 24576 3
crct10dif_pclmul 16384 1
usb_common 16384 2 xhci_hcd,usbcore
crct10dif_common 16384 3 crct10dif_generic,crc_t10dif,crct10dif_pclmul
i8042 40960 1 dell_laptop
rtc_cmos 28672 1
serio 28672 5 serio_raw,atkbd,i8042
dm_mod 155648 0
dax 45056 1 dm_mod
zfs 5697536 9
spl 126976 1 zfs
