I’m a new nixos user. I have gotten nixos working well on my laptop that uses an nvidia gpu. I’m now trying to get it working on my desktop, which has an intel arc A550.
I installed the iso for the gnome preset, which worked fine. However, now when I launch my system, it shows a blinking underscore in the top left corner. If I wait for a while I get:
Check BIOS again for an integrated graphics setting and if it’s there try to disable it. If there’s an option akin to System preferred GPU trying setting that to the proper GPU
did you also DisableIntegrated graphics Multi-Monitor option as the link suggested? Also, “auto” might be a bad idea, could you explicitly pick the card?
I tried installing with no DE and installing the i915 drivers like you said. That didn’t work. I’m admitting defeat and am just going to use the nix package manager on Linux Mint.
If you are reading this thread with the same problem as me and are able to solve it, please leave a reply.
If you’re experiencing the blinking underscore and can’t escape, I’d try doing a reinstall with no DE and then manually editing your config.
This config got me up and running with i3wm:
# your system. Help is available in the configuration.nix(5) man page
{ config, pkgs, callPackage, ... }:
imports =
./hardware-configuration.nix
environment.pathsToLink = ["/libexec"];
services.xserver = {
desktopManager = {
xterm.enable = false;
displayManager = {
defaultSession = "none+i3";
windowManager.i3 = {
extraPackages = with pkgs; [
dmenu
i3status
i3lock
i3blocks
# Bootloader.
boot.initrd.kernelModules = ["i915"];
# networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
# Enable networking
# Set your time zone.
time.timeZone = "America/Chicago";
i18n.extraLocaleSettings = {
LC_ADDRESS = "en_US.UTF-8";
LC_IDENTIFICATION = "en_US.UTF-8";
LC_MEASUREMENT = "en_US.UTF-8";
LC_MONETARY = "en_US.UTF-8";
LC_NAME = "en_US.UTF-8";
LC_NUMERIC = "en_US.UTF-8";
LC_PAPER = "en_US.UTF-8";
LC_TELEPHONE = "en_US.UTF-8";
LC_TIME = "en_US.UTF-8";
# Configure keymap in X11
layout = "us";
xkbVariant = "";
users.users.firesquid = {
isNormalUser = true;
description = "firesquid";
packages = with pkgs; [];
# Allow unfree packages
# $ nix search wget
vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
wget
firefox
git
neovim
rofi
kitty
# started in user sessions.
# programs.mtr.enable = true;
# programs.gnupg.agent = {
# enable = true;
# enableSSHSupport = true;
# Enable the OpenSSH daemon.
# Open ports in the firewall.
system.stateVersion = "23.11"; # Did you read the comment?
