Hi folks, ,
Motherboard: TUF GAMING X870-PLUS WIFI|Motherboards|ASUS Global
Kernel: 6.11.4 from unstable
Linux Firmware: 20241016 (from unstable)
I have system 24.05 version already installed but, I have kernel, linux-firmware and nvidia drivers from unstable.
uname -a: Linux tank0 6.11.4 #1-NixOS SMP PREEMPT_DYNAMIC Thu Oct 17 13:27:02 UTC 2024 x86_64 GNU/Linux
[ 7.365501] Bluetooth: Core ver 2.22
[ 7.365509] NET: Registered PF_BLUETOOTH protocol family
[ 7.365510] Bluetooth: HCI device and connection manager initialized
[ 7.365512] Bluetooth: HCI socket layer initialized
[ 7.365514] Bluetooth: L2CAP socket layer initialized
[ 7.365516] Bluetooth: SCO socket layer initialized
[ 7.865402] Bluetooth: hci0: HW/SW Version: 0x00000000, Build Time: 20240816133202
[ 9.195980] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.195984] Bluetooth: BNEP socket layer initialized
[ 26.250299] Bluetooth: hci0: Device setup in 18109067 usecs
[ 26.250303] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 26.410455] Bluetooth: MGMT ver 1.23
[ 26.429836] Bluetooth: RFCOMM TTY layer initialized
[ 26.429840] Bluetooth: RFCOMM socket layer initialized
[ 26.429843] Bluetooth: RFCOMM ver 1.11
lsmod
lsmod |grep bt
btusb 77824 0
btrtl 32768 1 btusb
btintel 69632 1 btusb
btbcm 24576 1 btusb
btmtk 32768 1 btusb
bluetooth 1073152 44 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/etc/systemd/system/bluetooth.service; enabled; preset: enabled)
Drop-In: /nix/store/5lavl80b872zxc3xv7qaiigm2q7y44cd-system-units/bluetooth.service.d
└─overrides.conf
Active: active (running) since Tue 2024-10-22 21:15:50 CEST; 3h 0min ago
Docs: man:bluetoothd(8)
Main PID: 1107 (bluetoothd)
Status: "Running"
IP: 0B in, 0B out
IO: 1.9M read, 0B written
Tasks: 1 (limit: 75921)
Memory: 2.9M (peak: 3.3M)
CPU: 27ms
CGroup: /system.slice/bluetooth.service
└─1107 /nix/store/4jk7imhlawwja56kdvqwiiznjv19zv91-bluez-5.75/libexec/bluetooth/bluetoothd -f /etc/bluetooth/main.conf
oct 22 21:16:08 tank0 bluetoothd[1107]: Endpoint registered: sender=:1.90 path=/MediaEndpoint/A2DPSource/opus_05
oct 22 21:16:08 tank0 bluetoothd[1107]: Endpoint registered: sender=:1.90 path=/MediaEndpoint/A2DPSink/opus_05_duplex
oct 22 21:16:08 tank0 bluetoothd[1107]: Endpoint registered: sender=:1.90 path=/MediaEndpoint/A2DPSource/opus_05_duplex
oct 22 21:16:08 tank0 bluetoothd[1107]: src/gatt-database.c:database_add_chrc() Failed to create characteristic entry in database
oct 22 21:16:08 tank0 bluetoothd[1107]: src/gatt-database.c:database_add_service() Failed to add characteristic
oct 22 21:16:08 tank0 bluetoothd[1107]: src/gatt-database.c:database_add_app() Failed to add service
oct 22 21:16:08 tank0 bluetoothd[1107]: src/gatt-database.c:client_ready_cb() Failed to create GATT service entry in local database
oct 22 21:18:32 tank0 bluetoothd[1107]: Controller resume with wake event 0x0
oct 22 23:55:30 tank0 bluetoothd[1107]: Controller resume with wake event 0x0
oct 22 23:56:24 tank0 bluetoothd[1107]: Controller resume with wake event 0x0
bluetoothctl
Waiting to connect to bluetoothd...
[bluetooth]# hci0 new_settings: powered bondable ssp br/edr le secure-conn wide-band-speech cis-central cis-peripheral iso-broadcaster sync-receiver
[bluetooth]# Agent registered
[bluetooth]# [CHG] Controller XX:XX:XX:5A:42:79 Pairable: yes
[bluetooth]# scan on
[bluetooth]# SetDiscoveryFilter success
[bluetooth]# Failed to start discovery: org.bluez.Error.InProgress
[bluetooth]# scan off
[bluetooth]# Failed to stop discovery: org.bluez.Error.Failed
