Bob is a high-level build system that isolates pipelines from the host system by executing them in a sandboxed shell with binaries installed by Nix to run them anywhere.
Designed to bring back the joy of microservice development.
Couple of interested questions:
If some of those boxes hit true for me, I might be interested to invest time in bringing prime support to GitHub - divnix/std: A DevOps framework for the SDLC with the power of Nix and Flakes. Good for keeping deadlines!
Specifically: Add `std flow` · Issue #49 · divnix/std · GitHub
PS: I pretty much recognize dagger.io, here — a coincidence? ![]()
Some random ideas brainstorming:
dependencies:
- ginkgo_1.16.5.nix
dependencies:
- //cellname/organellname/target-package
For true (data-)pipelines, it is sometimes required to process the outputs of a previous task as the inputs of a subsequent one. I’ve been looking at nushell (side-benefit: cross platform shell) in the past. @zuzuleinen what’s your thought on this?
Is the remote cache planned to be a nix cache
(at least as an option?). Would be nice if such a user friendly tooling would maintain (maybe even undocumented) escape hatches into a more nix-centric (as in “lingua franca”) world.
For context on why this is interesting for std: there is one possible adoption of std which postulates the 4 layers of packaging (package, entrypoint, OCI image, scheduler manifest + observability config). Since that schema can be highly standardized, any execution tooling (e.g. bob or a CI) can essentially be primed with a “preset” that already knows what to do (no need to define anything). Still, running that same thing locally through a nice CLI and combine it seamlessly with local dev env (via docker-compose) is pretty much a wide open known gap in its workflow.
docker-compose: have you considered foreman, hivemind & co. Or even something like nix-native, like aron as a possible type?
Hey David, thanks for your enthusiasm and helpful links.
nix-build under the hood (https://github.com/benchkram/bob/blob/6403a1de16304256725a06bba1522489ed1ccb27/pkg/nix/nix.go#L79) to download the packages and get the correct paths to the packages in `/nix/store/. But we don’t allow you to alter the given flags. But this could easily be made more generic.Yes it’s kind of related to dagger.io or earthly.dev as the problem space we are trying to solve is similar. Constructing a DAG on top of build isolation. With the difference of them using buildkit under the hood.
Never looked into nushell. Bob is made to execute task-pipeline… though there is nothing to stop you from setting datapipelines up with Bob. Though the output → inputs from task to task must be shared through the filesystem. Caching and artifacts might be a performance problem as the target for each task is stored in a tarball.
I have only looked very briefly into the little publicly available documentation on how cachix works. But I guess it’s technically possible. As of now it’s not planned as we are trying to solve problems for application developers.Though i will reconsider if i see a clear benefit.
You’ve got my attention… that definitely overlaps with our long term vision. Though i have mostly experience with building container images through docker build which we use in some projects to create containers to run them using bob run (which can execute docker compose files & control the lifecycle). Though it might take some time to stabilize bob run.
No, I wasn’t even aware of it. Checking….!
Thx for pointing out https://norouter.io in the repo, something like this looks very, very essential for having control over hybrid dev environments.
Does this answer your questions?
Cheers,
Matthias
Thanks for the detailed reply! I was actually just on the lookout for some code pointers…
I just tried to capture our current best practices (@ IOG / IOHK) in a publicly available pattern explainer:
The workings on how to obsolete CI description for all parts of the workflow except any “Probing & Attestation” stages (such as e2e testing, benchmarking, load testing, monkey testing, property testing, fuzzying, etc) is the following:
All involved organelles (packages.nix, entrypoints.nix, oci-images.nix & <shed>Charts.nix) are inherently typed and easily discoverable by a pipline tooling ootb (there is even already a hidden implementation of an after keyword in std that can by used to construe a DAG across cells, organelles and targets).
Each of these typed organelles (types are called esoterically “clades”) have well-known clade actions. For example, for clades.containers, there is copy-to-registry, or in full on the CLI: std //cell/oci-images/myimage:copy-to-registry.
Consequentially, for the core parts of building, testing up to publishing artifacts, the CI already could “know” what to do without any further instructions as a collateral side effect of code organization and nix-based (source-based) distribution.
So this is where I see a strong value of a “Bob preset for Standard” or something like that.
The beauty of Bob here is, that it can be made gradual: start with a bob.yaml and only adopt the stdized “4 Layers of Packaging” with some help from the “big boys” (in the subject of source-based distribution) in your organization… And it’ll be still bob run and feel magically the same. Just now, your downstream integrators also can experience the joy.
EDIT: in this context, please also have a look at the following draft doc on how to make OCI-image building a truly emergent property of the “entrypoint discussion” (between Devs & Ops).
As an application developer i’m very interested in waiting less with remote caches.
Indeed. In the javascript world, nx (https://nx.dev) even tries to replicate the Nix Cache, for example.
(And maybe that name is also a shameless rip, who knows)
Any specific usecase in mind?
Getting/Pushing artifacts from a remote is basically influenced by
(2) and (3) can be tuned for a specific use case.
Or did you mean rather the process of setting up a remote cache at all?
Write once. Build once.
Anywhere.
“Anywhere” as long as you are using Windows / Linux / MacOS ?
ad (3): this is an interesting point and has two aspects:
nx with a bad UX.In my opinion, the first point has the 80%, the second has probably the 20%.
A naive adoption of the Nix cache would probably be doable with a compatible hash calculation and with using the reproducible NAR format as opposed to the non-reproducible TAR format.
nix-community/go-nix has a nar implementation.
That would go a long way for interoperability and probably give you a solid cache implementation
(in the domain of binary artifacts) for free.
It wouldn’t solve the first point above, though. That can only be solved in a language-neutral way by jumping the hurdle and nixify the build (or integrate with every possible language-specific tooling — an operator’s / integrator’s nightmare)
Are you challanging an marketing hook-up statement for its degree of correctness and oversimplification?! ![]()
EDIT: This might be especially interesting and give bob some interoperability based on docker OCI runtime spec (even better), while still satisfying Nix’ fundamental derivation build interface.
bobsome interoperability based on docker, while still satisfying Nix’ fundamentalderivationbuild interface
This is not based on Docker but on the OCI runtime spec, it’s one level below what users would typically interact with in the container stack.
I’m too naive ![]()
