Bridge not working after reboot -> starts to work when starting tcpdump on the interface
Hello there,
I’ve got a really strange problem regarding my bridges on a NixOS 20.09 (problem also exists on 20.03).
The configuration look like this (names and addresses censored of course):
  networking = {
    useNetworkd = true;
    useDHCP = false;
    hostId = "39f2c5e3";
    firewall = {
      allowedTCPPorts = [ 22 ];
      allowedUDPPorts = [];
    hostName = "hostname";
    domain = "best.domain.at";
    nameservers = [ "9.9.9.9" ];
  systemd.network.netdevs."20-br-public" = {
    netdevConfig = {
      Kind = "bridge";
      Name = "br-public";
    extraConfig = ''
      [Bridge]
      VLANFiltering=true
  systemd.network.networks."30-int-enp2s0f1" = {
    matchConfig = {
      Name = "enp2s0f1";
    networkConfig = { Bridge = "br-public"; };
  systemd.network.networks."30-int-public" = {
    matchConfig = {
      Name = "br-public";
    address = [
      "127.0.0.1/24"
    gateway = [ "127.0.0.245" ];
When rebooting the system all looks good so far. The interfaces are up, the IP Addresses are configured and when checking the bridge I can see all needed interfaces as member of the bridge.
The connection just does not work. I’ve debugged a lot checking configuration and doing tcpdumps. After a time it started working without me changing anything, just lurking around.
It looks like the bridge starts to work after the bridge/all related interfaces went into promiscuous mode one because tcpdump was started.
After a reboot I ping the public IP without answer. Connecting to the system via Serial console and starting “tcpdump -n” it starts to answer.
Do someone else see this problem or has a tip what I could check to solve it?
I am happy to answer additional questions about the configuration/hardware if needed.
thanks,
Stefan
