Is there a way to build a directory of a nixos system like nixos-generators’s lxc
format would do, but without archiving the content? Too much time is wasted in tar
then untar
while rsync
should be must faster for my use case.
Btw, my use case is deploying nixos to a termux proot-distro environment. (It only partly works now, with systemd can’t start yet - I guess I should look into how Nixos-WSL achieved it)
Do you just mean you want to rsync
all the /nix/store
paths required for a NixOS system to a directory? You can build a NixOS closure and then use nix-store --query --requisites ./result
to get the list of directories that you need to copy.
no, I want the top level files as well, there are etc/
, sbin/
I am using nixos-generators which means result
is a tarball. If I build #nixosConfigurations.{namehere}.config.system.build.toplevel
with nixos.lib.nixosSystem {...}
the directory inside result
is a bit different from the tarball. Should I specify another attribute to build?
Other than the following, the only files in the tarball are in /nix/store
$ tar -tf $(nix run github:nix-community/nixos-generators -- -f lxc) | grep -v '^nix/store'
dev/
etc/
etc/os-release
nix/
nix-path-registration
proc/
sbin/
sbin/init
sys/
The only actual files in the tarball outside /nix/store
are os-release
, nix-path-registration
, and init
. Everything is in the store, and the root fs is populated by init
when the image is started. And init
is a symlink pointing to the toplevel
derivation’s init
program.
The important code to look at is system.build.tarball
, defined here. Also note the variety of other configuration options set in that file, such as boot.isContainer = true;
. And the script that actually assembles the tarball is here.
So I think you can make a configuration.nix
with imports = ["${modulesPath}/virtualisation/lxc-container.nix"];
, and assemble a directory with etc/os-release
and sbin/init
pointing at the files in system.build.toplevel
, and that’ll be basically the same as the tarball. The nix-path-registration
is a bit more complicated though, but also not entirely necessary.
That’s all I need, thank you very much for the pointer
hmm, I’m curious how to call that system.build.tarball
from nix build
+ flake, without involving nixos-generators?
The nixos-generators thing for lxc is extremely simple. Essentially all it does is import the lxc-container.nix
file from nixpkgs. You can just do that, and then you can build .#nixosConfigurations.${name}.config.system.build.tarball
just like you would toplevel
Thanks, it took me a while to read the source code of nixos-generators and several nixos modules that nixos-generators use to understand how things work together.
