Hi,
I’ve recently found out 26.05 has released and today (2026-05-31) wanted to do the upgrade. Seeing as I use a flake for the NixOS config, I just changed HomeManager’s and Nixpkgs’ version to pull from to 26.05 in the inputs attr. set and hit sudo nixos-rebuild switch.
However, and very unexpectedly on this super-stable OS otherwise, I ran into an issue. Not quite sure why, but the system always fails when building python3.12-3.12.13-doc at the buildSphinx phase (log below). I might be writing incorrectly here and should write to Sphinx devs, but I want to start from the top, i.e. NixOS. Any idea if the issue is known and are there steps how to fix it (I didn’t find anything, but maybe I used the wrong keywords)? Or is this Sphinx-only thing I should discuss there? In that case… any idea how to get the full log file of its output? It says it has some at /build/..., but expectedly there was no such path from the root, so I’m unsure where to look for that.
Thank you for any help.
The output of the nixos-rebuild command:
error: Cannot build '/nix/store/i99b9ai081igykh4wwjr464258nl95k1-python3.12-3.12.13-doc.drv'.
Reason: builder failed with exit code 2.
Output paths:
/nix/store/3gwj8amzqnkxzd6r11890822ii9hlb5w-python3.12-3.12.13-doc
Last 25 log lines:
> node, match_titles)
> File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/parsers/rst/states.py", line 215, in run
> results = StateMachineWS.run(self, input_lines, input_offset)
> File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/statemachine.py", line 234, in run
> context, next_state, result = self.check_line(
> context, state, transitions)
> File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/statemachine.py", line 446, in check_line
> return method(match, context, next_state)
> File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/parsers/rst/states.py", line 1409, in enumerator
> format, sequence, text, ordinal = self.parse_enumerator(match)
> File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/parsers/rst/states.py", line 1494, in parse_enumerator
> ordinal = int(self.enum.converters[sequence](text))
> TypeError: int() argument must be a string, a bytes-like object or a real number, not 'NoneType'
> The full traceback has been saved in:
> /build/sphinx-err-ykwu7l8f.log
> To report this error to the developers, please open an issue at <https://github.com/sphinx-doc/sphinx/issues/>. Thanks!
> Please also report this if it was a user error, so that a better error message can be provided next time.
For full logs, run:
nix log /nix/store/i99b9ai081igykh4wwjr464258nl95k1-python3.12-3.12.13-doc.drv
error: Cannot build '/nix/store/napm0273y4j5avnpn8ds77qjd1b79nvz-user-environment.drv'.
Reason: 1 dependency failed.
Output paths:
/nix/store/yxkajflx8c1yd24l7xm54by8ddbsq5n4-user-environment
error: Build failed due to failed dependency
error: Cannot build '/nix/store/7rapqfp6a4q7pjw5pldb7hp8bl0vccmc-etc.drv'.
Output paths:
/nix/store/48xyri1bzbl0lzp7nyhckric2pgcp0vw-etc
error: Cannot build '/nix/store/g1526pir9j3j85kqxs8cyx4p9d7c7j7y-activate.drv'.
Output paths:
/nix/store/k0cdli8s87k1g00a04h26cjzgwh7w41v-activate
error: Cannot build '/nix/store/xqx6qvbxhpir7pqhjvkj3yhapnq7v5az-nixos-system-nixos-26.05.20260529.e8e446a.drv'.
Output paths:
/nix/store/5cqmc81ygi17gp8yj9gby4nvw8y1h0ng-nixos-system-nixos-26.05.20260529.e8e446a
Command 'nix --extra-experimental-features 'nix-command flakes' build --print-out-paths '/etc/nixos#nixosConfigurations."nixos".config.system.build.toplevel' --no-link --show-trace' returned non-zero exit status 1.
The log (output from nix log ... from the previous output):
Sourcing sphinx-hook
Running phase: unpackPhase
@nix { "action": "setPhase", "phase": "unpackPhase" }
unpacking source archive /nix/store/k06n7vwxpi8bb3kkij87ncid2v08qn0y-Python-3.12.13.tar.xz
source root is Python-3.12.13
setting SOURCE_DATE_EPOCH to timestamp 1772541570 of file "Python-3.12.13/pyconfig.h.in"
Running phase: patchPhase
@nix { "action": "setPhase", "phase": "patchPhase" }
@nix { "action": "setPhase", "phase": "updateAutotoolsGnuConfigScriptsPhase" }
Updating Autotools / GNU config script to a newer upstream version: ./config.sub
Updating Autotools / GNU config script to a newer upstream version: ./config.guess
Running phase: installPhase
@nix { "action": "setPhase", "phase": "installPhase" }
no Makefile or custom installPhase, doing nothing
Running phase: buildSphinxPhase
@nix { "action": "setPhase", "phase": "buildSphinxPhase" }
Executing buildSphinxPhase
Executing sphinx-build with html builder
Running Sphinx v9.1.0
loading translations [en]... locale_dir /build/Python-3.12.13/Doc/locales/en/LC_MESSAGES does not exist
done
making output directory... done
building [mo]: targets for 0 po files that are out of date
writing output...
building [html]: targets for 501 source files that are out of date
updating environment: locale_dir /build/Python-3.12.13/Doc/locales/en/LC_MESSAGES does not exist
[new config] 501 added, 0 changed, 0 removed
reading sources... [ 0%] about
reading sources... [ 0%] bugs
reading sources... [ 1%] c-api/abstract
reading sources... [ 1%] c-api/allocation
reading sources... [ 1%] c-api/apiabiversion
reading sources... [ 1%] c-api/arg
reading sources... [ 1%] c-api/bool
reading sources... [ 2%] c-api/buffer
reading sources... [ 2%] c-api/bytearray
reading sources... [ 2%] c-api/bytes
reading sources... [ 2%] c-api/call
reading sources... [ 2%] c-api/capsule
reading sources... [ 3%] c-api/cell
reading sources... [ 3%] c-api/code
reading sources... [ 3%] c-api/codec
reading sources... [ 3%] c-api/complex
reading sources... [ 3%] c-api/concrete
reading sources... [ 4%] c-api/contextvars
reading sources... [ 4%] c-api/conversion
reading sources... [ 4%] c-api/coro
reading sources... [ 4%] c-api/datetime
reading sources... [ 4%] c-api/descriptor
reading sources... [ 5%] c-api/dict
reading sources... [ 5%] c-api/exceptions
reading sources... [ 5%] c-api/file
reading sources... [ 5%] c-api/float
reading sources... [ 5%] c-api/frame
reading sources... [ 6%] c-api/function
reading sources... [ 6%] c-api/gcsupport
reading sources... [ 6%] c-api/gen
reading sources... [ 6%] c-api/hash
reading sources... [ 6%] c-api/import
reading sources... [ 7%] c-api/index
reading sources... [ 7%] c-api/init
reading sources... [ 7%] c-api/init_config
reading sources... [ 7%] c-api/intro
reading sources... [ 7%] c-api/iter
reading sources... [ 8%] c-api/iterator
reading sources... [ 8%] c-api/list
reading sources... [ 8%] c-api/long
reading sources... [ 8%] c-api/mapping
reading sources... [ 8%] c-api/marshal
reading sources... [ 9%] c-api/memory
reading sources... [ 9%] c-api/memoryview
reading sources... [ 9%] c-api/method
reading sources... [ 9%] c-api/module
reading sources... [ 9%] c-api/none
reading sources... [ 10%] c-api/number
reading sources... [ 10%] c-api/objbuffer
reading sources... [ 10%] c-api/object
reading sources... [ 10%] c-api/objimpl
reading sources... [ 10%] c-api/perfmaps
reading sources... [ 11%] c-api/refcounting
reading sources... [ 11%] c-api/reflection
reading sources... [ 11%] c-api/sequence
reading sources... [ 11%] c-api/set
reading sources... [ 11%] c-api/slice
reading sources... [ 12%] c-api/stable
reading sources... [ 12%] c-api/structures
reading sources... [ 12%] c-api/sys
reading sources... [ 12%] c-api/tuple
reading sources... [ 12%] c-api/type
reading sources... [ 13%] c-api/typehints
reading sources... [ 13%] c-api/typeobj
reading sources... [ 13%] c-api/unicode
reading sources... [ 13%] c-api/utilities
reading sources... [ 13%] c-api/veryhigh
reading sources... [ 14%] c-api/weakref
reading sources... [ 14%] contents
reading sources... [ 14%] copyright
reading sources... [ 14%] deprecations/c-api-pending-removal-in-3.14
reading sources... [ 14%] deprecations/c-api-pending-removal-in-3.15
reading sources... [ 15%] deprecations/c-api-pending-removal-in-future
reading sources... [ 15%] deprecations/index
reading sources... [ 15%] deprecations/pending-removal-in-3.13
reading sources... [ 15%] deprecations/pending-removal-in-3.14
reading sources... [ 15%] deprecations/pending-removal-in-3.15
reading sources... [ 16%] deprecations/pending-removal-in-3.16
reading sources... [ 16%] deprecations/pending-removal-in-future
reading sources... [ 16%] distributing/index
reading sources... [ 16%] extending/building
reading sources... [ 16%] extending/embedding
reading sources... [ 17%] extending/extending
reading sources... [ 17%] extending/index
reading sources... [ 17%] extending/newtypes
reading sources... [ 17%] extending/newtypes_tutorial
reading sources... [ 17%] extending/windows
reading sources... [ 18%] faq/design
Versions
* Platform: linux; (Linux-6.12.60-x86_64-with-glibc2.42)
* Python version: 3.13.13 (CPython)
* Sphinx version: 9.1.0
* Docutils version: 0.22.4
* Jinja2 version: 3.1.6
* Pygments version: 2.20.0
Last Messages
extending/windows
faq/design
Loaded Extensions
* sphinx.ext.mathjax (9.1.0)
* alabaster (1.0.0)
* sphinxcontrib.applehelp (2.0.0)
* sphinxcontrib.devhelp (2.0.0)
* sphinxcontrib.htmlhelp (2.1.0)
* sphinxcontrib.serializinghtml (2.0.0)
* sphinxcontrib.qthelp (2.0.0)
* audit_events (1.0)
* availability (1.0)
* c_annotations (1.0)
* changes (1.0)
* glossary_search (1.0)
* implementation_detail (1.0)
* issue_role (1.0)
* lexers (1.0)
* misc_news (1.0)
* pydoc_topics (1.0)
* pyspecific (1.0)
* sphinx.ext.coverage (9.1.0)
* sphinx.ext.doctest (9.1.0)
* sphinx.ext.extlinks (9.1.0)
* python_docs_theme (2026.4)
Traceback
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/cmd/build.py", line 432, in build_main
app.build(args.force_all, args.filenames)
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/application.py", line 442, in build
self.builder.build_update()
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/builders/__init__.py", line 381, in build_update
self.build(
to_build,
...<2 lines>...
method='update',
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/builders/__init__.py", line 409, in build
updated_docnames = set(self.read())
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/builders/__init__.py", line 525, in read
self._read_serial(docnames)
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/builders/__init__.py", line 590, in _read_serial
self.read_doc(docname)
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/builders/__init__.py", line 653, in read_doc
doctree = _parse_str_to_doctree(
content,
...<6 lines>...
transforms=self._registry.get_transforms(),
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/util/docutils.py", line 902, in _parse_str_to_doctree
parser.parse(content, document)
File "/nix/store/7rcmdx7w0lg08rbkb4fd52a19xchdqv1-python3.13-sphinx-9.1.0/lib/python3.13/site-packages/sphinx/parsers.py", line 99, in parse
self.statemachine.run(inputlines, document, inliner=self.inliner)
File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/parsers/rst/states.py", line 182, in run
results = StateMachineWS.run(self, input_lines, input_offset,
input_source=document['source'])
File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/parsers/rst/states.py", line 1277, in indent
elements = self.block_quote(indented, line_offset)
File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/parsers/rst/states.py", line 1294, in block_quote
self.nested_parse(blockquote_lines, line_offset, blockquote)
File "/nix/store/s1fya244ggpq1jhy8cx4ybk2favrn521-python3.13-docutils-0.22.4/lib/python3.13/site-packages/docutils/parsers/rst/states.py", line 357, in nested_parse
my_state_machine.run(block, input_offset, self.memo,
node, match_titles)
node, match_titles)
