Build multi-layered project using nix
I have a project that follows the following build structure:
  • some rust parts are compiled down using wasm-pack to wasm
  • the package is then included in a frontend, the frontend is built using npm run buld
  • the resulting dist folder (index.html) is then included in my backend (again written in rust)
My question know is how can I build such a project using nix, my current build strucuture is the one specified below:
FROM rust:alpine AS development
RUN apk update && apk upgrade && apk add npm git alpine-sdk openssh curl
RUN curl -fsS https://dotenvx.sh | sh
RUN cargo install wasm-pack
RUN cargo install --locked bacon
RUN rustup component add rustfmt
FROM development AS build
ARG BUILD_VARIANT=release
WORKDIR /workspace
COPY . .
RUN VARIANT=${BUILD_VARIANT} make all
RUN VARIANT=${BUILD_VARIANT} make test
WORKDIR /artifacts
RUN cp /workspace/target/${BUILD_VARIANT}/backend .
RUN strip backend
FROM scratch AS run
WORKDIR /app
COPY --from=build /artifacts/backend .
CMD ["/app/backend"]
And the makefile is here:
cargo fetch
dotenvx run -- wasm-pack build --${VARIANT} --out-dir ${CURRENT_ROOT}/wasm-pkgs/backend_interfaces sources/rust/backend_interfaces
npm install --workspaces --include=optional
npm run build --workspaces --${VARIANT}
dotenvx run -- cargo build ${CARGO_RELEASE_FLAG}
In the last step (cargo build), the backend embeds the generated index.html in the resulting binary using rust_embed.
The generated wasm package is included in my package.json like this:
  "optionalDependencies": {
    "backend_interfaces": "file:../../../wasm-pkgs/backend_interfaces"
My question here is how can I download the dependencies from npm and cargo before actually running the build scripts? Do you have any pointers on this?
So my main two problems are:
  1. My frontend needs some rust parts (that are included via wasm) to be built, those are referenced via the file: URL in package.json
  2. My backend needs the frontend to be already built, because the resulting html files get included in the binary using rust_embed
I have come up with:
  description = "Nix environment";
    nixpkgs.url = "github:NixOS/nixpkgs/8b27c1239e5c421a2bbc2c65d52e4a6fbf2ff296";
    flake-utils.url = "github:numtide/flake-utils/04c1b180862888302ddfb2e3ad9eaa63afc60cf8";
    flake-utils.lib.eachSystem [
      flake-utils.lib.system.x86_64-linux
      flake-utils.lib.system.aarch64-linux
      flake-utils.lib.system.x86_64-darwin
      flake-utils.lib.system.aarch64-darwin
    ] ( system:
        pkgs = import nixpkgs {
          inherit system;
          config.allowUnfree = false;
        stdEnv = pkgs.swiftPackages.stdenv;
        globalPackages = with pkgs; [
            # tools
            dotenvx
            zsh
            git
            gnumake
            cmake
            # rust toolchain
            rustc
            cargo
            wasm-pack
            # typescript toolchain
            nodejs_23
       package = stdEnv.mkDerivation {
            name = "package";
            src = ./.;
            buildInputs = with pkgs; globalPackages;
            phases = [ "unpackPhase" "buildPhase" "installPhase" ];
            buildPhase = ''
            installPhase = ''
              mkdir -p $out/bin
              cp my-executable $out/bin/
        devShells = {
          default = pkgs.mkShell.override
            stdenv = stdEnv;
            packages = with pkgs; globalPackages ++ [
              (vscode-with-extensions.override {
                  vscode = vscodium;
                  vscodeExtensions = with vscode-extensions; [
                      bbenoist.nix
                      streetsidesoftware.code-spell-checker
                      vscode-extensions.rust-lang.rust-analyzer
                      vscode-extensions.dbaeumer.vscode-eslint
                      vscode-extensions.esbenp.prettier-vscode
                  ] ++ vscode-utils.extensionsFromVscodeMarketplace [ ];
            DONT_PROMPT_WSL_INSTALL = true; #  to supress warnings issued by vscode on wsl
        packages = {
          default = package;
