Hello there, I’m rather new in Nix and trying to create a package to “wrap” Discourse installation because I currently have a non-Nix managed Discourse in 3.3.0beta1 (that I would like to migrate to Nix) but Nixpkgs only provides 3.1.0, which doesn’t accept my backup.
So far I’ve created the following bash to try using Docker inside the building process:
builder.sh
export PATH="$docker/bin"
docker ps
But it fails ![]()
ERROR: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get “http://%2Fvar%2Frun%2Fdocker.sock/_ping”: dial unix /var/run/docker.sock: connect: permission denied
However, trying to use it directly with my user works:
$ /nix/store/956bjn9hvpvha1bs7pwq1nhpddbhjh03-docker-24.0.5/bin/docker ps Fri May 17 13:29:55 2024
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
Or even with nix-shell it’s OK:
nix-shell --pure
[nix-shell:~/dev/nix-apprentissage/build-with-docker]$ source builder.sh
What am I missing here?
