I’m trying to build a container using podman buit it keeps failing when i try to run any bash command to build the image. It looks like this is due to the fact that the OCI runtime is using the wrong path to invoke bash commands. It’s using /bin/sh instead of the one in the /nix/store.
❯ podman build --format docker -t haystack-dev . haystack-dev -> master ?
STEP 1/4: FROM docker.io/ubuntu/python:3.12-24.04_stable
STEP 2/4: RUN pip install haystack-ai
error running container: from /nix/store/fp3m0k2piiikfax9233dg5648r277h5i-podman-helper-binary-wrapper/bin/crun creating container for [/bin/sh -c pip install haystack-ai]: executable file `/bin/sh` not found: No such file or directory
: exit status 1
Error: building at STEP "RUN pip install haystack-ai": while running runtime: exit status 1
I used the settings in this guide to add sh to the path: Rootless podman setup with Home Manager
systemd.user.extraConfig = ''
DefaultEnvironment="PATH=/run/current-system/sw/bin:/run/wrappers/bin:${lib.makeBinPath [ pkgs.bash ]}"
But I’m still seeing the same issue.
