Building a package for Boomaga
Hi I’m trying to create a package for Boomaga (GitHub - Boomaga/boomaga: Boomaga provides a virtual printer for CUPS. This can be used for print preview or for print booklets.). The package compiles well and it install two things, a cups backend for it and a corresponding gui app. The GUI app works well, but the cups_backend does not work, because it needs to write to /var/cache/boomaga and it fails as permission denied. How can I make this work?
This what I could come up with:
{ lib
, stdenv
, fetchFromGitHub
, cmake
, cups
, qtbase
, qttools
, wrapQtAppsHook
, pkg-config
, poppler
stdenv.mkDerivation rec {
  pname = "boomaga";
  version = "3.0.0"; # Update this to the correct version
  src = fetchFromGitHub {
    owner = "Boomaga";
    repo = "boomaga";
    rev = "v${version}";
    sha256 = "sha256-ThiyZ/fTwp+E639HavUv9WbRE+RxGbRwcPqXSuVWdaQ="; # Update with correct hash
  nativeBuildInputs = [
    cmake
    wrapQtAppsHook
    pkg-config
  buildInputs = [
    cups.dev
    qtbase
    qttools
    poppler
  cmakeFlags = [
    "-DCMAKE_INSTALL_PREFIX=${placeholder "out"}"
    "-DCUPS_PPD_DIR=${placeholder "out"}/share/cups/model/boomaga"
    "-DCUPS_BACKEND_DIR=${placeholder "out"}/lib/cups/backend"
  # postPatch = ''
  #     substituteInPlace src/backend/cups_backend/main.cpp \
  #         --replace "/var/cache/boomaga" "/var/cache/cups/boomaga"
  meta = with lib; {
    description = "Virtual printer for viewing and editing before printing";
    homepage = "https://www.boomaga.org/";
    license = licenses.gpl2Plus;
    maintainers = with maintainers; [ ]; # Add your name if you're maintaining this package
    platforms = platforms.linux;
This is the virtual printer config I am using to create the virtual printer in my configuration:
{pkgs, ...}: let
  boomaga = pkgs.libsForQt5.callPackage ./boomaga.nix {};
  services.avahi = {
    nssmdns4 = true;
    openFirewall = true;
    boomaga
  hardware.printers = {
    ensurePrinters = [
        name = "Boomaga";
        deviceUri = "boomaga:/";
        model = "boomaga/boomaga.ppd";
        description = "Boomaga Virtual Printer";
        location = "Local Virtual Printer";
        ppdOptions = {
          # Add any specific PPD options here if needed
  services.dbus.packages = [boomaga];
  services.printing.drivers = with pkgs; [hplipWithPlugin boomaga];
It feels like /var/cache/boomaga is a directory that needs to be created from your NixOS configuration, with the right ownership/permissions using systemd.tmpfiles.rules, for example:
    systemd.tmpfiles.rules = [
      "d /var/cache/boomaga 0700 user group - -"
^ Adjust user & group for your needs.
I did that, like this
      "d /var/cache/boomaga 0775 cups lp - -"
But then boomaga also creates a user directory in the folder and changes the owner to the user, which is errors out
“[Boomaga backend] ERROR: Can’t change owner on directory /var/cache/boomaga/nithin: Operation not permitted”
Edit: I also added
tmp-files for the user folder too, then it tries to change owner of the job files, it fails too.
This is the source code.
https://github.com/Boomaga/boomaga/blob/7f7ad4754b20a1027c5095b660c5229353b64c8d/src/backend/cups_backend/main.cpp#L116
I’ve modified it to ignore this chown, then it errors while creating a job file, seen here
https://github.com/Boomaga/boomaga/blob/7f7ad4754b20a1027c5095b660c5229353b64c8d/src/backend/cups_backend/main.cpp#L153
