I’m using nix package manager on Mac OS Ventura 13.6. When nvim-r is activated in neovim, it attempts to build and install nvimcom but fails with the output included below. Any ideas on how I might resolve the “ld: library not found for -lintl” issue? Thanks!
before_rns.R stdout: * checking for file ‘/Users/danke/.local/share/nvim/lazy/R.nvim/nvimcom/DESCRIPTION’ …
OK
- preparing ‘nvimcom’:
- checking DESCRIPTION meta-information …
OK- cleaning src
- checking for LF line-endings in source and make files and shell scripts
- checking for empty or unneeded directories
- building ‘nvimcom_0.9.41.tar.gz’
/nix/store/0m04cmy32vs1686pzjqajsh50arbv8m4-clang-wrapper-16.0.6/bin/cc -I"/nix/store/6s73b2138xz0k5xc2w9bf8c5ic74js46-R-4.3.2/lib/R/include" -DNDEBUG -isystem /nix/store/rjgv94p1nnj02v0f9r2jpann9x02b4vw-libcxx-16.0.6-dev/include/c++/v1 -fPI
C -g -O2 -c common.c -o common.o
C -g -O2 -c nvimcom.c -o nvimcom.o
C -g -O2 -c rd2md.c -o rd2md.o
/nix/store/0m04cmy32vs1686pzjqajsh50arbv8m4-clang-wrapper-16.0.6/bin/cc -dynamiclib -Wl,-headerpad_max_install_names -undefined dynamic_lookup -L/nix/store/6s73b2138xz0k5xc2w9bf8c5ic74js46-R-4.3.2/lib/R/lib -L/nix/store/j3yw5w8pbdv4argnmx7i4i0lvg
lnh7ll-libcxx-16.0.6/lib -o nvimcom.so common.o nvimcom.o rd2md.o -L/nix/store/6s73b2138xz0k5xc2w9bf8c5ic74js46-R-4.3.2/lib/R/lib -lR -lintl -Wl,-framework -Wl,CoreFoundationWhy build nvimcom: Nvimcom not installed
before_rns.R stderr:
.build_packages() exit status 0
- installing to library ‘/Users/danke/Library/R/arm64/4.3/library’
- installing source package ‘nvimcom’ …
** using staged installation
** libs
using C compiler: ‘clang version 16.0.6’
using SDK: ‘MacOSX14.2.sdk’
clang-16: error: linker command failed with exit code 1 (use -v to see invocation)
make: *** [/nix/store/6s73b2138xz0k5xc2w9bf8c5ic74js46-R-4.3.2/lib/R/share/make/shlib.mk:10: nvimcom.so] Error 1
ERROR: compilation failed for package ‘nvimcom’- removing ‘/Users/danke/Library/R/arm64/4.3/library/nvimcom’
Error in do_exit(status = status) : .install_packages() exit status 1
Error in do_exit(status = status) : .install_packages() exit status 1Execution halted
