I’m relatiely new to nix, so I’m trying to slog through what I can. But I’ve hit a point where I’m a bit lost.
What I’m trying to do, generally, is to create a shell.nix that I can take with me across machines to have a single, unified, consistent terminal environment as much as possible. First question: is that actually reasonable?
The main question, regardless of whether that’s a good idea or not, is that I’ve installed asdf-vm in the main shell and I want to use that to install particular versions of Python. I need a specific version of Python for a work project that’s pinned. When I run asdf install python 3.9.5, I keep running into various errors. Here are two that I can’t get past, and I feel like I’m missing something fundamental here.
First is the SSL module, complaining that libssl is missing.
Could not build the ssl module!
Python requires an OpenSSL 1.0.2 or 1.1 compatible libssl with X509_VERIFY_PARAM_set1_host().
The second is that it can’t build zlib.
I have both openssl and zlib included in buildInputs, but I see that they both have ‘dev’ outputs. I looked at Nixpkgs 23.11 manual | Nix & NixOS but I’m confused as to what I actually need to do with this information. I feel like if I understand what I’m missing here, I could probably fix most everything else.
The sample nix shell I’m playing with is pasted below:
nixpkgs = fetchTarball "https://github.com/NixOS/nixpkgs/tarball/nixos-unstable";
pkgs = import nixpkgs { config = {}; overlays = []; };
pkgs.mkShell {
buildInputs = with pkgs; [
libffi
# note: also tried openssl.dev, same issue
openssl
zlib
packages = with pkgs; [
cacert
curl
openssh
which
wget
zip
asdf-vm
shellHook = ''
source ${pkgs.asdf-vm}/etc/profile.d/asdf-prepare.sh
source ~/.bashrc
Then I run:
nix-shell sample.nix --pure
asdf plugin add python
I’d appreciate any links to any relevant info or any ideas here. I’ve been searching for a while and I’ve hit some deadends.
