From time to time I refactor the expressions in Nixpkgs, whether mine or someone else’s.
The reasons are multiple:
cosmetic formatting
finalAttrs design pattern
removing or banishing bad language constructs such as
recand nestedwith, according to the Best Practices -
migration to by-name hierarchy
Technical decisions based on intuition more than a technical and weary examination
In this last category, recently I am unifying the .override interface (a.k.a. the input set) of some packages.
I have started with bochs, and it is working fine (except unrelated, typical errors on Darwin), but two specific cases were a bit polemic.
For now I will leave the other case to a new post. In this I will talk about the Duckstation update PR
Triggered by an update PR by SuperSamus, I migrated and refactored the expression that builds Duckstation. In order to do it, I modified the expression to use callPackage instead of qt6.callPackage as before.
Further, the new Duckstation release required the application of a patch, not in the Duckstation code but rather into a dependency, namely shaderc.
That being said, originally SuperSamus built the patched shaderc inside the Duckstation expression. Basically, the caller provides a pristine shaderc, so that the expression patches and builds shaderc before building duckstation itself.
Instead of this approach, I preferred to keep the expression “agnostic” about its inputs: duckstation receives whatever shaderc is provided, while the caller (at top-level) provides the correctly patched shaderc.
Supersandro2000 raised two objections about this.
- The first was about
callPackageVSqt6.callPackage. - The second was about patched shaderc inside VS outside the expression.
Summarizing my decisions, I chose callPackage in order to make the expression compatible with by-name hierarchy, and I patched shaderc outside duckstation because it keeps the override interface cleaner and predictable.
This post is too long already, I will vent my full opinion tomorrow. For now I expect I have provided a clear picture about what is going on.
Calling @SuperSamus @Sandro as participants of the conversation.
