This year at VandyHacks I’ll be hosting a Nix workshop on Friday (2021-10-08) 9 to 10 pm central U.S. time (UTC-6). The workshop is intended for people with no prior Nix experience but who inevitably have run into a myriad of dependency and developer environment issues. We’ll also demonstrate more advanced topics such as cross-compilation. All are welcome to attend!
Couple of questions:
1- You mentioned Robotic Operating System but as far as I know, the package is not in nixpkgs. There is a third-party overlay but it has about 80% of the official ROS packages. So what is the recommended way of having ROS or ROS2 in NixOS?
2- You mentioned how to do cross-compilation for an Arm target. I wonder, is it possible to “run” a binary which was compiled for a foreign target architecture? Like, is it possible to execute an Arm binary in a x86-64 system?
3- Can’t we incorporate .envrc inside shell.nix so all project config settings and vars would be in a single place? If it is possible, is it recommended to do so?
To my knowledge, the overlay seems to be the most complete way to do it currently, but at some point in the future my co-presenter and I might take on porting ROS packages in Nixpkgs for macOS and Linux.
Yes, NixOS has support for emulation via QEMU. You can also add boot.binfmt.emulatedSystems = [ "aarch64-linux" ]; to your configuration.nix, see this for details.
Sure, if you need to set environment variables you could do it all in a shell.nix. .envrc is just needed for direnv to automatically reload your environment/you may want to store secrets in it instead of shell.nix.
But if we use lorri it also reloads the env if shell.nix changes, right? It seems to me .envrc is completely redundant in Nix context if we use lorri but is needed in non-nix distros where direnv is used.
Speaking of secrets, suppose we need an API_KEY to do some REST requests. Where should we put the secret?
If we use an env var, it would be accessible from other processes in the same shell => Insecure
If we use a file with special privileges, the consumer scripts/programs should also have elevated privileges => Inconvenient
