Hi. I have a very simple flake which should use callCabal2nix
to create a shell for a cabal project in a child folder using a custom GHC environment. The reason this is needed is that, without the nativeBuildInputs extended with a customGhc environment that has access to the propagatedBuildInputs of the project, the zlib
library (a C dependency) is not found. But having a customGhc be based on a separate folder breaks with this error in callCabal2nix:
error:
at /builtin/derivation.nix:9:12: (source not available)
… while evaluating derivation 'nix-shell'
whose name attribute is located at /nix/store/ka3vmkgvsn6cj8dywj7n1xl3bm54gxm7-source/pkgs/stdenv/generic/make-derivation.nix:352:7
… while evaluating attribute 'nativeBuildInputs' of derivation 'nix-shell'
at /nix/store/ka3vmkgvsn6cj8dywj7n1xl3bm54gxm7-source/pkgs/stdenv/generic/make-derivation.nix:396:7:
395| depsBuildBuild = elemAt (elemAt dependencies 0) 0;
396| nativeBuildInputs = elemAt (elemAt dependencies 0) 1;
397| depsBuildTarget = elemAt (elemAt dependencies 0) 2;
error: builder for '/nix/store/bghblpsfk9y2f7vvir3bgh99ih7gdwka-cabal2nix-rectify-backend.drv' failed with exit code 1;
last 1 log lines:
> cabal2nix: user error (*** Found neither a .cabal file nor package.yaml. Exiting.)
Here’s the flake.nix
description = "";
pkgs = import nixpkgs {
inherit system;
packageName = "rectify-backend";
haskellPackages = pkgs.haskellPackages;
cabalPackages = haskellPackages.callCabal2nix packageName ./rectify-backend {};
cabalPropagated = builtins.filter (d: !(isNull d)) cabalPackages.propagatedBuildInputs;
customGhc = haskellPackages.ghcWithPackages (ps: cabalPropagated);
packages.${packageName} = cabalPackages;
defaultPackage = self.packages.${system}.${packageName};
buildInputs = [
# For Haskell
haskellPackages.haskell-language-server
haskellPackages.ghcid
haskellPackages.cabal-install
# For Haskell's C dependencies - blas, lapack and zlib
nativeBuildInputs = [
customGhc
This works if the .cabal
file is in the same folder as flake.nix
though. But I don’t know why callCabal2Nix is looking in the wrong place. My file structure is this:
├── cabal.project
├── flake.lock
├── flake.nix
├── hmm.nix
└── rectify-backend
├── app
│ ├── Ex.hs
│ └── Main.hs
├── rectify-backend.cabal
└── src
├── Effect.hs
├── Oleg.hs
├── RandoNeur.hs
├── ServerEx.hs
├── SimulatedAnnealing.hs
└── Surface.hs
cabal.project
is just packages: */*.cabal
and the rectify-backend.cabal file is very plain, here’s the relevant section:
cabal-version: 2.2
version: 0.1.0.0
synopsis:
homepage:
license: NONE
author: Deco
maintainer: decomuricy@gmail.com
category: None
executable rectify
import: defaults
hs-source-dirs: app
main-is: Main.hs
build-depends:
base
, rectify-backend
, servant
, servant-server
, warp
, wai
, wai-cors
, wai-websockets
, websockets
, servant-websockets
, aeson
, rio
, stm
, text
