I am seeing an error in the log of unknown os or session here:
IpcInitConnectionLinux::GetOsSessionForProcessId: received unknown os session 4294967295 for process 3492!
2024/01/04 18:25:38.186 1224 140280430851776 S!! IpcInitConnection::Received_Control_InitIPC: IPC connection failed, session not found: type = 4 pid = 3492, Errorcode=11
2024/01/04 18:25:38.186 1224 140280430851776 S! InterProcessNetwork::HandleCommand: Could not send to target because session ID is unknown: CC=1 CT=1
AcceptServer::HandleAccept: new connection from 127.0.0.1:59970
2024/01/04 18:29:02.437 1224 140280430851776 S IpcInitConnection::Received_Control_InitIPC: Connecting process: 3492
2024/01/04 18:29:02.437 1224 140280430851776 S! IpcInitConnectionLinux::GetOsSessionForProcessId: received unknown os session 4294967295 for process 3492!
2024/01/04 18:29:02.438 1224 140280430851776 S!! IpcInitConnection::Received_Control_InitIPC: IPC connection failed, session not found: type = 4 pid = 3492, Errorcode=11
2024/01/04 18:29:02.438 1224 140280430851776 S! InterProcessNetwork::HandleCommand: Could not send to target because session ID is unknown: CC=1 CT=1
2024/01/04 18:29:18.395 1224 140280414066368 S TcpProcessConnector::HandleRead(): Socket gracefully closed (PID=3492)
2024/01/04 18:29:18.395 1224 140280414066368 S TcpProcessConnector::CloseConnection(): PID=3492
2024/01/04 18:29:18.646 1224 140280414066368 S AcceptServer::HandleAccept: new connection from 127.0.0.1:37380
2024/01/04 18:29:18.688 1224 140280422459072 S IpcInitConnection::Received_Control_InitIPC: Connecting process: 3492
2024/01/04 18:29:18.688 1224 140280422459072 S! IpcInitConnectionLinux::GetOsSessionForProcessId: received unknown os session 4294967295 for process 3492!
2024/01/04 18:29:18.689 1224 140280422459072 S!! IpcInitConnection::Received_Control_InitIPC: IPC connection failed, session not found: type = 4 pid = 3492, Errorcode=11
2024/01/04 18:29:18.689 1224 140280422459072 S! InterProcessNetwork::HandleCommand: Could not send to target because session ID is unknown: CC=1 CT=1
Hopefully this is ok to post. Why is my ipad not able to connect?
