Everyone
I have installed microsoft edge using nix-env and I can’t uninstall it
I did “nix-env --uninstall microsoft-edge-dev-122.0.2353.0”
Command completed no error however it is still there!!
Also “nix-env -qi” nothing is showing, however freaking EDGE is still installed
I tried:
“nix-env -e microsoft-edge-dev” → warning: selector ‘microsoft-edge-dev’ matched no installed derivations
“nix-env --uninstall microsoft-edge-dev*” → warning: selector ‘microsoft-edge-dev*’ matched no installed derivations
which microsoft-edge →
which: no microsoft-edge in (/run/wrappers/bin:/home/marcelb/.nix-profile/bin:/nix/profile/bin:/home/marcelb/.local/state/nix/profile/bin:/etc/profiles/per-user/marcelb/bin:/nix/var/nix/profiles/default/bin:/run/current-system/sw/bin)
I tried: sudo nix-delete -r microsoft-edge → nix-delete: command not found
Thanks for your support, however I have reboot many times and still there
The .xdesktop is pointing to
/nix/store/y9w7fvkv2ks0g7wg2k69g9679p2r53rf-microsoft-edge-dev-122.0.2353.0/bin/microsoft-edge-dev
and if I try to install a newer version (123.xx.xx.xx) to try and uninstall it after, I can’t have access to the new version, only to the 122.xx.xx.xx installed
