Hi,
I have an Raylib application that I developed on NixOS.
Now I want to get it working on my MacOS laptop too.
When building with cc, I get this error fatal error: 'Carbon/Carbon.h' file not found, which is included here: raylib/src/external/glfw/src/cocoa_platform.h.
This'Carbon/Carbon.h' is a file in the Cocoa framework and is packaged with the xcode install. When I compile raylib with /usr/bin/cc instead of the one in my nix store it works.
I’m really new to linking libs and I can’t find the needed documentation to proceed.
I’m either looking for a way to override the stdenv cc to /usr/bin/cc or a way to link the needed libs.
Thanks in advance!
Here is my flake.nix:
naersk.url = "github:nix-community/naersk";
rust-overlay = {
url = "github:oxalica/rust-overlay";
nixpkgs.follows = "nixpkgs";
flake-utils.follows = "flake-utils";
outputs = { self, nixpkgs, flake-utils, naersk, rust-overlay }:
flake-utils.lib.eachDefaultSystem (system: let
overlays = [ (import rust-overlay) ];
# Read from `rust-toolchain.toml` instead of adding `rust-bin.nightly.latest.default` to devShell `buildInputs`
rustToolchain = pkgs.pkgsBuildHost.rust-bin.fromRustupToolchainFile ./rust-toolchain.toml;
naerskLib = pkgs.callPackage naersk {
cargo = rustToolchain;
rustc = rustToolchain;
pkgs = import nixpkgs {
inherit system overlays;
config = {
allowUnfree = true;
# Libraries that are mostly needed for raylib to build
libraries = with pkgs; [
cmake
] ++ pkgs.lib.lists.optionals stdenv.isLinux [
clang
libclang
libcxx # C++ std library
libGL
xorg.libX11
xorg.libXrandr
xorg.libXinerama
xorg.libXcursor
xorg.libXi
xorg.libXi
libatomic_ops
mesa
alsa-lib
glibc
# [Wayland]
wayland
wayland-protocols
libxkbcommon
] ++ pkgs.lib.lists.optionals stdenv.isDarwin [
# darwin.xcode # This is monstrously huge, often fails to build and is installed anyway
packages = with pkgs; [
# Inputs needed at compile-time
nativeBuildInputs = with pkgs; [ rustToolchain ];
# Inputs needed at runtime
buildInputs = with pkgs; [ ] ++ packages ++ libraries;
packages.default = naerskLib.buildPackage {
src = ./.;
devShells = {
default = pkgs.mkShell {
inherit buildInputs;
nativeBuildInputs = nativeBuildInputs ++ [
pkgs.cargo-watch
# shellHook = ''
# export LD_LIBRARY_PATH=${pkgs.lib.makeLibraryPath libraries}
