I have been trying to use ‘ccache’ under NixOS. I have successfully used it on Debian Linux and it reduces the compile time from an hour to less than five minutes for my projects. I have set the following options in configuration.nix:
nix =
maxJobs = 2;
sandboxPaths = [
(toString config.programs.ccache.cacheDir)
nixPath =
options.nix.nixPath.default ++
"nixpkgs-overlays=/etc/nixos/overlays/"
and have confirmed that this adds ‘sandbox paths’:
build-users-group = nixbld
max-jobs = 2
cores = 0
sandbox = true
extra-sandbox-paths = /nix/var/cache/ccache
substituters = https://cache.nixos.org/
trusted-substituters =
trusted-public-keys = cache.nixos.org-1:6NCHdD59X431o0gWypbMrAURkbJ16ZPMQFGspcDShjY=
auto-optimise-store = false
require-sigs = true
trusted-users = root
allowed-users = *
builders =
system-features = nixos-test benchmark big-parallel kvm
sandbox-fallback = false
to /etc/nix/nix.conf. I have also added:
programs.ccache =
cacheDir = "/nix/var/cache/ccache";
packageNames =
"iup-cd"
"iup-ftgl"
"iup-im"
"iup-iup"
"iup-pdflib7"
to configuration.nix. Then I changed my derivation so that stdenv was replaced with ccacheStdenv and when I run the derivation, the following error is displayed:
/nix/store/5b62ia6vj72nf1mmdlfbxawpb9hjr8w9-stdenv-linux/setup: line 1512: /homeless-shelter/.cache/ccache/tmp:: No such file or directory
builder for '/nix/store/bhh4cskzdc3rz5vxlq5qg4jm836dx9pb-iup-im.drv' failed with exit code 127
cannot build derivation '/nix/store/dlsqaxhv21665yzr9m3cm3s6cyxfhz9a-system-path.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/k5g1x9a2811d0lskz7gyw0yhlk3mcmrc-nixos-system-Delbert-21.11.337514.4c560cc7ee5.drv': 1 dependencies couldn't be built
error: build of '/nix/store/k5g1x9a2811d0lskz7gyw0yhlk3mcmrc-nixos-system-Delbert-21.11.337514.4c560cc7ee5.drv' failed
Is ccache for NixOS broken or are there more configuration changes that I need to make.
