Changing nix-build's TMPDIR from shell.nix
I’m trying to use nix-shell with a shell.nix file to get a clean development environment but I don’t know how to change the location of the temporary build directories.
The buildInputs packages are built in /tmp but this path doesn’t have enough space and I get an error: [Errno 28] No space left on device during the build.
I tried running nix-shell with a modified TMPDIR environment variable but it only affects the location of the nix-shell temporary files. The nix-build files are still put in /tmp.
I also tried to export a new value for TMPDIR in the shellHook but it doesn’t work.
How can I change the TMPDIR of nix-build when it’s started by nix-shell?
Here’s my shell.nix:
  pkgs = import <nixpkgs> {};
  pkgs.mkShell {
    name = "something";
    buildInputs = with pkgs; [
      python38
      python38Packages.pytorchWithCuda
    shellHook = ''
I’m not using NixOS.
If this is a mutli-user install, you need to modify the Nix daemon’s TMPDIR.
