I wanted to install something new, but home-manager switch
failed because one of the dependency of a package fail to build.
Running home-manager switch
will show
error: clickgen-1.2.0 not supported for interpreter python3.10
I followed the trace and it turns out that I had bibata-cursors
installed and clickgen
is in its’ buildInputs.
I am a noob, so i’m not sure how to solve this problem, I tried to use overlay to override the disabled attr in clickgen
, but it didn’t work.
How can I make home-manager switch
work without having to uninstall bibata-cursors
or waiting for clickgen
to support python3.10?
Full trace:
… while evaluating anonymous lambda
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/development/interpreters/python/mk-python-derivation.nix:30:1:
29|
30| { name ? "${attrs.pname}-${attrs.version}"
31|
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/customisation.nix:69:16:
68| let
69| result = f origArgs;
70|
… while evaluating 'makeOverridable'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/customisation.nix:67:24:
66| */
67| makeOverridable = f: origArgs:
68| let
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/top-level/python-packages.nix:29:12:
28| let
29| ff = f origArgs;
30| overrideWith = newArgs: origArgs // (if pkgs.lib.isFunction newArgs then newArgs origArgs else newArgs);
… while evaluating 'makeOverridablePythonPackage'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/top-level/python-packages.nix:27:37:
26| # This function introduces `overridePythonAttrs` and it overrides the call to `buildPythonPackage`.
27| makeOverridablePythonPackage = f: origArgs:
28| let
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/development/python-modules/clickgen/default.nix:15:1:
14|
15| buildPythonPackage rec {
16| pname = "clickgen";
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/development/python-modules/clickgen/default.nix:1:1:
1| { lib
2| , stdenv
… from call site
68| let
70|
66| */
68| let
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/customisation.nix:168:34:
167|
168| in if missingArgs == [] then makeOverridable f allArgs else throw error;
169|
… while evaluating 'callPackageWith'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/customisation.nix:117:35:
116| */
117| callPackageWith = autoArgs: fn: args:
118| let
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/top-level/python-packages.nix:1754:14:
1753|
1754| clickgen = callPackage ../development/python-modules/clickgen { };
1755|
… while evaluating 'toPythonApplication'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/top-level/python-packages.nix:82:25:
81| # Convert a Python library to an application.
82| toPythonApplication = drv:
83| drv.overrideAttrs( oldAttrs: {
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/top-level/all-packages.nix:3062:36:
3061|
3062| clickgen = with python3Packages; toPythonApplication clickgen;
3063|
… while evaluating the attribute 'clickgen.override'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/top-level/all-packages.nix:3062:3:
3061|
3063|
… while evaluating 'isDerivation'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/attrsets.nix:427:18:
426| */
427| isDerivation = x: x.type or null == "derivation";
428|
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/stdenv/generic/make-derivation.nix:193:8:
192| checkDependencyList' = positions: name: deps: lib.flip lib.imap1 deps (index: dep:
193| if lib.isDerivation dep || isNull dep || builtins.typeOf dep == "string" || builtins.typeOf dep == "path" then dep
194| else if lib.isList dep then checkDependencyList' ([index] ++ positions) name dep
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/stdenv/generic/make-derivation.nix:192:81:
191| checkDependencyList = checkDependencyList' [];
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/lists.nix:117:32:
116| */
117| imap1 = f: list: genList (n: f (n + 1) (elemAt list n)) (length list);
118|
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/lists.nix:117:29:
116| */
118|
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/stdenv/generic/make-derivation.nix:221:13:
220| (map (drv: drv.__spliced.hostHost or drv) (checkDependencyList "depsHostHost" depsHostHost))
221| (map (drv: drv.crossDrv or drv) (checkDependencyList "buildInputs" buildInputs))
222| ]
… from call site
… while evaluating 'getOutput'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/attrsets.nix:598:23:
597| */
598| getOutput = output: pkg:
599| if ! pkg ? outputSpecified || ! pkg.outputSpecified
… from call site
… while evaluating the attribute 'buildInputs' of the derivation 'bibata-cursors-1.1.2'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/stdenv/generic/make-derivation.nix:270:7:
269| // (lib.optionalAttrs (attrs ? name || (attrs ? pname && attrs ? version)) {
270| name =
271| let
… while evaluating the attribute 'passAsFile'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/pkgs/build-support/buildenv/default.nix:77:5:
76| # XXX: The size is somewhat arbitrary
77| passAsFile = if builtins.stringLength pkgs >= 128*1024 then [ "pkgs" ] else [ ];
78| }
… while evaluating the attribute 'passAsFile' of the derivation 'home-manager-path'
270| name =
271| let
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:576:44:
575| defnsByName' = byName "config" (module: value:
576| [{ inherit (module) file; inherit value; }]
577| ) configs;
… while evaluating 'dischargeProperties'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:827:25:
826| */
827| dischargeProperties = def:
828| if def._type or "" == "merge" then
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:756:137:
755| defs' = concatMap (m:
756| map (value: { inherit (m) file; inherit value; }) (builtins.addErrorContext "while evaluating definitions from `${m.file}':" (dischargeProperties m.value))
757| ) defs;
… while evaluating definitions from `/home/bill/.nix-defexpr/channels/home-manager/modules/home-environment.nix':
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:755:28:
754| # Process mkMerge and mkIf properties.
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:755:17:
… while evaluating the attribute 'values'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:868:7:
867| in {
868| values = concatMap (def: if getPrio def == highestPrio then [(strip def)] else []) defs;
869| inherit highestPrio;
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:769:9:
768| in {
769| values = defs''';
770| inherit (defs'') highestPrio;
… while evaluating the attribute 'mergedValue'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:775:5:
774| # Type-check the remaining definitions, and merge them. Or throw if no definitions.
775| mergedValue =
776| if isDefined then
… while evaluating the option `home.activation.installPackages.data':
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:741:9:
740| in warnDeprecation opt //
741| { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
742| inherit (res.defsFinal') highestPrio;
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/modules.nix:292:72:
291| # For definitions that have an associated option
292| declaredConfig = mapAttrsRecursiveCond (v: ! isOption v) (_: v: v.value) options;
293|
… from call site
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/attrsets.nix:401:20:
400| then recurse (path ++ [name]) value
401| else f (path ++ [name]) value;
402| in mapAttrs g;
… while evaluating 'g'
at /nix/store/gjmj42s0if0fpd3y5p9jkxcpkfvgkd9v-nixos/nixos/lib/attrsets.nix:398:19:
397| g =
398| name: value:
399| if isAttrs value && cond value
… from call site
… while evaluating the attribute 'data'
at /home/bill/.nix-defexpr/channels/home-manager/modules/lib/dag.nix:84:9:
83| name = n;
84| data = v.data;
85| after = v.after ++ dagBefore dag n;
at /home/bill/.nix-defexpr/channels/home-manager/modules/lib/dag.nix:90:37:
89| in if sorted ? result then {
90| result = map (v: { inherit (v) name data; }) sorted.result;
91| } else
… while evaluating 'mkCmd'
at /home/bill/.nix-defexpr/channels/home-manager/modules/home-environment.nix:638:17:
637| let
638| mkCmd = res: ''
639| _iNote "Activating %s" "${res.name}"
… from call site
… while evaluating the attribute 'text' of the derivation 'activation-script'
270| name =
271| let
… while evaluating the attribute 'buildCommand' of the derivation 'home-manager-generation'
270| name =
271| let
