Cmake custom command shell script not found
Nix package build is not able to call shell scripts defined in cmake as custom command.
When i build it (with nix-build -A) i get a cannot execute: required file not found error.
Running phase: buildPhase
build flags: -j8 SHELL=/nix/store/717iy55ncqs0wmhdkwc5fg2vci5wbmq8-bash-5.2p32/bin/bash
[100%] Generating foo
current: /build/source absolut: /build/source
-rwxr-xr-x 1 nixbld nixbld 20 Jan  1  1970 /build/source/foo.sh
/nix/store/717iy55ncqs0wmhdkwc5fg2vci5wbmq8-bash-5.2p32/bin/bash: line 1: /build/source/foo.sh: cannot execute: required file not found
As far as i can tell with ls the file exists and has permissions to be executed. One workaround i found was to patch the cmake to include bash in front of the script.
Why does this fail? I would rather not have to patch the cmake.
Steps to reproduce:
Summary
To reproduce create a directory with these 2 files:
cmake_minimum_required(VERSION 3.6 FATAL_ERROR)
project(shelltest)
add_custom_command(
    OUTPUT foo
    COMMAND echo "current: ${CMAKE_CURRENT_SOURCE_DIR} absolut: ${CMAKE_SOURCE_DIR}"
    COMMAND ls -la ${CMAKE_CURRENT_SOURCE_DIR}/foo.sh
    COMMAND ${CMAKE_CURRENT_SOURCE_DIR}/foo.sh
    DEPENDS foo.sh
add_custom_target(run ALL
    DEPENDS foo)
#!/usr/bin/env bash
echo "Hoii"
And use a nix package expression like this:
  lib,
  stdenv,
  cmake,
stdenv.mkDerivation (finalAttrs: {
  pname = "test";
  version = "1.0.0";
  src = lib.cleanSource /path/to/folder/with/files/from/above;
  nativeBuildInputs = [
    cmake
You probably just need to use patchShebangs on it. (I suspect the error is because /usr/bin/env isn’t in the sandbox.)
Looking at the examples a well places patchShebangs will do the trick.
postPatch = ''
    patchShebangs ./
