Conan system dependecies issue
I am working on a cross-platform project and they use conan as their package manager and cmake as build system. Problem arises, when conan tries to install system dependencies such as opengl and xorg. Log from conan:
Detecting target platform...
Target platform: linux
-- Conan executing:
Setting profile: /home/senpie/my-project/common/cmake/platform/conan/linux.profile
Setting build profile: /home/senpie/my-project/common/cmake/platform/conan/linux.profile
Running conan in /home/senpie/Documents/my-project
======== Input profiles ========
Profile host:
[settings]
arch=x86_64
build_type=Debug
compiler=clang
compiler.cppstd=20
compiler.libcxx=libstdc++
compiler.version=16
os=Linux
[conf]
tools.system.package_manager:mode=install
tools.system.package_manager:sudo=True
Profile build:
[settings]
arch=x86_64
build_type=Debug
compiler=clang
compiler.cppstd=20
compiler.version=16
os=Linux
[conf]
======== Computing dependency graph ========
... etc
    opengl/system#4df6fecde4084386beded3ed0e56e4ea - Cache
    xorg/system#98f82cb669e4ebc6b4d9d8a4f3f1faf4 - Cache
... etc
======== Computing necessary packages ========
opengl/system: A default system package manager couldn't be found for nixos, system packages will not be installed.
xorg/system: A default system package manager couldn't be found for nixos, system packages will not be installed.
======== Installing packages ========
opengl/system: Already installed! (8 of 15)
xorg/system: Already installed! (11 of 15)
ERROR: xorg/system: Error in package_info() method, line 102
	pkg_config.fill_cpp_info(
	ConanException: PkgConfig failed. Command: pkg-config --print-provides xcb-icccm --print-errors
    stdout:
    stderr:
    Package xcb-icccm was not found in the pkg-config search path.
    Perhaps you should add the directory containing `xcb-icccm.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'xcb-icccm' found
CMake Error at common/cmake/conan.cmake:74 (message):
  Conan install failed for Debug (1)
Call Stack (most recent call first):
  common/cmake/conan.cmake:127 (invoke_conan)
  CMakeLists.txt:17 (include)
-- Configuring incomplete, errors occurred!
Inside my flake:
      self,
      nixpkgs,
    }@inputs:
      system = "x86_64-linux";
      devShells.${system}.default = pkgs.mkShellNoCC {
          git
          cmake
          pkg-config
          ninja
          conan
          clang_16
          xorg.libX11 # needs maintainer
          xorg.libfontenc # needs maintainer
          xorg.libICE # needs maintainer
          xorg.libSM # needs maintainer
          xorg.libXau # needs maintainer
          xorg.libXaw # xaw7 needs maintainer
          xorg.libXcomposite # needs maintainer
          xorg.libXcursor # needs maintainer
          xorg.libXdamage # needs maintainer
          xorg.libXdmcp # needs maintainer
          xorg.libXext # needs maintainer
          xorg.libXi # needs maintianer
          xorg.libXfixes
          xorg.libXinerama
          xorg.libXmu
          xorg.libXpm
          xorg.libXrandr
          xorg.libXrender
          xorg.libXres
          xorg.libXt
          xorg.libXtst
          xorg.libXv
          xorg.libXvMC
          xorg.libXxf86dga
          xorg.libXxf86misc
          xorg.libXxf86vm
          xorg.libxcb
          xorg.libxkbfile
          xorg.libXScrnSaver
          xorg.libxshmfence
          xorg.libXp
          xorg.libXpresent
          xorg.libpciaccess
          xorg.libpthreadstubs
        shellHook = ''
          echo "Setting up project..."
As you can see from the flake, I run conan, it failed on a single xorg package, I would add it and run again. It again would fail, I would add it, and it would fail on the next package. So the question is how to avoid listing every xorg dependency and make it work? In nix center I saw there are like 3000+ packages in xorg namespace. I really don’t want to name them one by one. Thanks!
