Hello everyone, I have a problem exposing two apps written in Python in a devShell declared in a flake. Both apps have a module with the same name “lib”, but this seems to create conflicts.
Here are the outputs of the flake.nix:
app1 = pkgs.python3Packages.callPackage ./app1 { };
app2 = pkgs.python3Packages.callPackage ./app2 { };
packages.app1 = app1;
packages.app2 = app2;
packages = with pkgs; [
app1
app2
Here are the derivations:
app1/default.nix
{ buildPythonApplication, pandas, setuptools, }:
buildPythonApplication rec {
pname = "app1";
version = "0.1.0";
pyproject = true;
src = ./.;
build-system = [ setuptools ];
dependencies = [ pandas ];
doCheck = false;
app2/default.nix
{ buildPythonApplication, setuptools, plotly, }:
pname = "app2";
version = "0.1.0";
pyproject = true;
src = ./.;
dependencies = [ plotly ];
doCheck = false;
The apps are simple “Hello World” programs. The main file for both is identical:
import lib
def main():
p = lib.Person()
print(p.name())
print(lib)
if __name__ == '__main__':
main()
Modules
app1/lib/__init__.py
class Person:
def name(self):
return "Frank"
app2/lib/__init__.py
class Person:
def name(self):
return "Anna"
setup.py for both apps
app1/setup.py
setup(
name='app1',
packages=['lib'],
version='0.1.0',
author='',
install_requires=install_requires,
scripts=[
'app1.py'
entry_points={
'console_scripts': ['app1=app1:main']
app2/setup.py
setup(
name='app2',
packages=['lib'],
version='0.1.0',
author='',
scripts=[
'app2.py'
entry_points={
'console_scripts': ['app2=app2:main']
When I try to run app2, it loads the “lib” module from app1:
λ app1
Frank
<module 'lib' from '/nix/store/kdsm5991239kdr2p0ipzk4jwk9jghlix-app1-0.1.0/lib/python3.12/site-packages/lib/__init__.py'>
λ app2
Frank
Is there a way to prevent this and ensure that app2 correctly loads its own module?
λ app2
Anna
<module 'lib' from '/nix/store/gcdynkwv3hrffq1iks0lcxar6r5xi4yj-app2-0.1.0/lib/python3.12/site-packages/lib/__init__.py'>
Thank you very much!
