I am posting this here since wayvnc works perfectly on an Arch-based Hyprland implementation, but on my Nix Hyprland running 23.11 I can’t get two different VNC clients to connect.
Wayvnc installs fine, and when I activate it, wayvnc 0.0.0.0
it appears to be functioning. If I look to see if the appropriate port is listening using lsof -i -P -n
it gives me the right output (same as on my Arch Hyprland):
wayvnc 7518 userXX 9u IPv4 57528 0t0 TCP *:5900 (LISTEN)
The VNC client that has a log (RealVNC) says that it timedout due to a lack of response from the computer.
Has anyone gotten wayvnc to work on a Nix Hyprland setup? Any specific configurations used?
Thanks in advance for any help.
