I have setup a erigon etherum node running inside Native NixOS containers. my zfs mouint point are legacy and mounted by declarative config.
when set container to autostart, the caplin inside erigon always started with an old number (might be the snapshot date i have taken), and after a while, this app crashed with a long callstack about “mdbx errors”. the erigon service inside container are not autostart, even i wait for a while and manually start service, i still get this error.
I have solved it with a workaround, by delaying the bootstrap of container after zfs mounted.
- set contianer autostart = false
- make a systemd service, wait for zfs done, and manually start container
systemd.services.enableEtherumContainer = {
description = "enableEtherumContainer";
unitConfig = {
After = ["zfs.target" ];
script = ''
#echo $(/run/current-system/sw/bin/zfs get mounted sn640/erigondata)
/run/current-system/sw/bin/nixos-container start etherum
/run/current-system/sw/bin/nixos-container run etherum -- systemctl start erigon
serviceConfig = {
Type = "oneshot";
RemainAfterExit = true;
#ExecStart = "/run/current-system/sw/bin/nixos-container start etherum";
how to adjust the startup order of Native NixOS containers?
This doesn’t particularly make sense. ZFS file systems are mounted before local-fs.target
is reached, and nixos containers have default dependencies which implies they’re ordered after local-fs.target
. This really shouldn’t make a difference, and there shouldn’t be a problem in the first place.
you are right, i can’t reproduce the errors…
I think I might fix this by pointing to a new bootstrap script , and manually boot the correct one.
I can partly reproduce now…
The only difference conf is wantedBy = [ "default.target" ];
make service autoboot.
after i see the serivice log
May 04 13:13:52 etherum erigon-start[186]: mdbx_setup_dxb:15946 filesize mismatch (expect 2544650682368b/310626304p, have 2544701014016b/310632448p)
i immeidately shutdown the service not to continue (it may continue works fine ),
while remove wantedBy = [ "default.target" ];
and manual start by triggering nixos-container run etherum -- systemctl start erigon
don’t get this message
my conf settings:
# your system. Help is available in the configuration.nix(5) man page
{ config, pkgs, ... }:
imports =
./hardware-configuration.nix
# Bootloader.
boot.loader.grub.enable = true;
boot.loader.grub.device = "/dev/sda";
boot.loader.grub.useOSProber = true;
boot.kernelModules = with config.boot.kernelModules; [ "msr" ];
boot.kernelPackages = config.boot.zfs.package.latestCompatibleLinuxPackages;
boot.kernelParams = [ "nohibernate" "init_on_alloc=0" "zfs.zfs_arc_sys_free=${toString(1024*1024*1024*24)}" ];
boot.supportedFilesystems = [ "zfs" ];
boot.zfs.forceImportRoot = false;
boot.zfs.extraPools = [ "sn640" ];
fileSystems."/mnt/data" = {
device = "sn640/data";
fsType = "zfs";
fileSystems."/mnt/erigondata" = {
device = "sn640/erigondata";
fsType = "zfs";
powerManagement.enable = true;
networking.hostId = "286c56fb";
# networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
# Enable networking
# Set your time zone.
time.timeZone = "Asia/Shanghai";
i18n.extraLocaleSettings = {
LC_ADDRESS = "zh_CN.UTF-8";
LC_IDENTIFICATION = "zh_CN.UTF-8";
LC_MEASUREMENT = "zh_CN.UTF-8";
LC_MONETARY = "zh_CN.UTF-8";
LC_NAME = "zh_CN.UTF-8";
LC_NUMERIC = "zh_CN.UTF-8";
LC_PAPER = "zh_CN.UTF-8";
LC_TELEPHONE = "zh_CN.UTF-8";
LC_TIME = "zh_CN.UTF-8";
# Configure keymap in X11
services.xserver = {
layout = "us";
xkbVariant = "";
users.users.swz = {
isNormalUser = true;
description = "swz";
extraGroups = [ "networkmanager" "wheel" "docker"];
packages = with pkgs; [];
users.users.shiwenze = {
description = "for postgresql";
users.users.root.openssh.authorizedKeys.keys = [
# note: ssh-copy-id will add user@your-machine after the public key
# but we can remove the "@your-machine" part
# Allow unfree packages
# $ nix search wget
vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
wget
lm_sensors
bmon
git
iotop
stress-ng
tmux
frp
chromium
postgresql
environment.pathsToLink = [ "/usr/local/go/bin" ];
# started in user sessions.
# programs.mtr.enable = true;
# programs.gnupg.agent = {
# enable = true;
# enableSSHSupport = true;
# Enable the OpenSSH daemon.
# Open ports in the firewall.
networking.firewall.enable = false;
nix.settings.substituters = ["https://mirror.sjtu.edu.cn/nix-channels/store"];
system.stateVersion = "23.11"; # Did you read the comment?
virtualisation.docker.enable = true;
virtualisation.docker.daemon.settings = {
#data-root = "/mnt/data/docker_root";
registry-mirrors = [ "https://docker.mirrors.ustc.edu.cn/" ];
systemd.services.frpslocal = {
description = "frpslocal";
unitConfig = {
After = "network.target";
serviceConfig = {
# Type = "simple";
# KillMode = "process";
User = "swz";
Restart = "always";
RestartSec = 0;
ExecStart = "${pkgs.frp}/bin/frps -c /home/swz/frps.toml";
systemd.services.frpclocal = {
description = "frpclocal";
unitConfig = {
Requires = "frpslocal";
serviceConfig = {
# Type = "simple";
User = "swz";
Restart = "always";
RestartSec = 5;
ExecStart = "${pkgs.frp}/bin/frpc -c /home/swz/frpc.toml";
enable = false;
unitConfig = {
script = ''
serviceConfig = {
Type = "oneshot";
systemd.services.undervolt = {
description = "undervolt";
# unitConfig = {
serviceConfig = {
Type = "oneshot";
ExecStart = "${pkgs.undervolt}/bin/undervolt --core -70 --cache -70";
services.samba = {
securityType = "user";
openFirewall = true;
extraConfig = ''
workgroup = WORKGROUP
server string = smbnix
netbios name = smbnix
security = user
#use sendfile = yes
#max protocol = smb2
# note: localhost is the ipv6 localhost ::1
hosts allow = 192.168. 127.0.0.1 localhost
hosts allow = 0.0.0.0/0
guest account = nobody
map to guest = bad user
shares = {
share = {
path = "/mnt/data/share";
browseable = "yes";
"read only" = "no";
"guest ok" = "no";
"create mask" = "0755";
"directory mask" = "0755";
"force user" = "swz";
"force group" = "users";
services.samba-wsdd = {
services.nginx = {
virtualHosts."_" = {
locations."/" = {
proxyPass = "https://www.baidu.com";
extraConfig = ''
proxy_read_timeout 61s;
proxy_buffering off;
listen = [ { addr = "*"; port = 5801; } ];
virtualisation.libvirtd.enable = true;
programs.virt-manager.enable = true;
programs.chromium.enable = true;
networking.interfaces.enp5s0.ipv4.addresses = [{
address = "10.25.0.3";
prefixLength = 24;
networking.nat = {
internalInterfaces = ["ve-+" "ve-+"];
externalInterface = "wlp4s0";
# Lazy IPv6 connectivity for the container
enableIPv6 = true;
networking.hosts = {
"20.205.243.166" = ["github.com"];
containers.etherum = {
autoStart = true;
privateNetwork = true;
hostAddress = "192.168.100.11";
localAddress = "192.168.100.12";
hostAddress6 = "fc00::1";
localAddress6 = "fc00::2";
bindMounts = {
"/mnt/data/git/erigon" = {
hostPath = "/mnt/data/git/erigon";
isReadOnly = false;
hostPath = "/mnt/erigondata";
isReadOnly = false;
config = { config, pkgs, lib, ... }: {
systemd.services.erigon = {
#path = [ pkgs.su ];
unitConfig = {
After = ["network.target" "local-fs.target"];
script = "/mnt/data/git/erigon/booterigon.sh";
serviceConfig = {
# Type = "simple";
#Restart = "always";
RestartSec = 0;
#ExecStart = "/erigon/build/bin/erigon --internalcl --txpool.disable --datadir /mnt/erigondata --http.port 8546 --authrpc.port 8552 --http.api eth,debug,net,trace,web3,erigon --torrent.port=42070 --prune=disabled --nat=stun";
#ExecStart = "/erigon/build/bin/erigon --db.size.limit=4TB --db.pagesize=4kb --injternalcl=true --txpool.disable --datadir /mnt/erigondata --http.port 8546 --authrpc.port 8552 --http.api eth,debug,net,trace,web3,erigon --torrent.port=42070 --prune=disabled --nat=stun --staticpeers enode://d04e70020071d2182f61cfe22c03ea469107089d56c91960a193652a36dd2463d6a903ec510cbaf46c4290805e54eee83154e67f2f174e700deb9c3260473ba5@10.25.0.2:30303";
networking = {
firewall = {
enable = false;
# Use systemd-resolved inside the container
# Workaround for bug https://github.com/NixOS/nixpkgs/issues/162686
useHostResolvConf = lib.mkForce false;
services.resolved.enable = true;
services.resolved.fallbackDns = [
"223.5.5.5"
"2400:3200::1"
services.resolved.extraConfig = ''
DNS=2400:3200::1 223.5.5.5
dig
vim
traceroute
containers.cloudflared = {
autoStart = true;
#privateNetwork = true;
#hostAddress = "192.168.100.11";
#localAddress = "192.168.100.13";
#hostAddress6 = "fc00::1";
#localAddress6 = "fc00::3";
forwardPorts = [
containerPort = 7020;
hostPort = 7020;
protocol = "tcp";
networking = {
firewall = {
enable = false;
systemd.services.cloudflared = {
path = [ pkgs.su ];
unitConfig = {
serviceConfig = {
# Type = "simple";
Restart = "always";
RestartSec = 0;
ExecStart = "${pkgs.cloudflared}/bin/cloudflared tunnel --no-autoupdate --edge-ip-version 6 run --token xxxx";
"2400:3200::1"
"223.5.5.5"
cloudflared
services.zfs.trim.enable = true;
services.zfs.autoScrub.enable = true;
services.zfs.autoScrub.interval = "daily";
