My main question here then is - how do I do include fenix for this within a default.nix for a derivation for nixpkgs? Or is there another way to do this?
I’m 99.9% sure this kind of PR would not be accepted, fwiw.
Very likely, the stdlib stuff is surprisingly capable. I don’t know the answer firsthand and I’m concerned that it may touch on cross-compilation which I haven’t had to learn about yet. You may get a little further if you read this manual section:
What’s the software you want to package, just out of curiosity? Most WASM things I’m acquainted with still need something else to be useful, some host/runtime application that evaluates it.
My question is more on how do I import fenix in a default.nix rather than by a flake. Is it ok to just fetchFromGithub for it in nixpkgs?
The application is rerun-cli - it’s a visualisation tool for computer vision/robotics. It contains both a native viewer and a web-viewer, hence it needs the wasm.
My point was that the nixpkgs reviewers are extremely unlikely to accept a PR that introduces an external dependency on fenix, or any other community code that lives outside nixpkgs’ repo. Since that was your stated goal, I wanted to warn you it’s probably a non-starter tactic.
