Hello guys! I’m working on a new rust project, but I’m getting the following
error message:
--- stderr
thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: `PKG_CONFIG_ALLOW_SYSTEM_CFLAGS="1" PKG_CONFIG_ALLOW_SYSTEM_LIBS="1" "pkg-config" "--libs" "--cflags" "x11" "x11 >= 1.4.99.1"` did not exit successfully: exit status: 1
error: could not find system library 'x11' required by the 'x11' crate
I’m using the following shell.nix:
rust-overlay = builtins.fetchTarball "https://github.com/oxalica/rust-overlay/archive/master.tar.gz";
pkgs = import <nixpkgs> {
overlays = [ (import rust-overlay) ];
toolchain = pkgs.rust-bin.fromRustupToolchainFile ./toolchain.toml;
pkgs.mkShell rec {
packages = [ toolchain ];
buildInputs = with pkgs; [
rustup
xorg.libX11
xorg.libXcursor
xorg.libXrandr
xorg.libXi
shaderc
directx-shader-compiler
libGL
vulkan-headers
vulkan-loader
vulkan-tools
vulkan-tools-lunarg
vulkan-validation-layers
shellHook = ''
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:${builtins.toString (pkgs.lib.makeLibraryPath buildInputs)}";
does anyone know what I’m doing wrong?
