Marked Howto in the hope some best practices fall out of this thread.
I am creating a default.nix file for an open source library. Contributors should be able to clone the project, run nix-shell, and be ready to contribute, build documentation, and so on. So long as I stay within the bounds of the current Nix package set this is straightforward to create. But there is one package which needs a more recent version than is in the 18.09 channel. I’d like to update this single package, only in this default.nix file (not system-wide). That sounds like a job for overlays, but I’m having trouble getting this to work.
Here’s the default.nix file without the package that needs to be updated. It works fine:
{ nixpkgs ? import <nixpkgs> { } }:
pkgs = [
nixpkgs.nodejs
nixpkgs.yarn
nixpkgs.stack
nixpkgs.stdenv.mkDerivation {
name = "env";
buildInputs = pkgs;
Now, I need to also add the mkdocs package in order to build the project documentation. The version available in nixpkgs is v0.17, but this project requires v1.0. So I need to adjust this default.nix to use a newer version of mkdocs than is available in the package set, and that sounds like a job for an overlay.
Fortunately, there is already a Nix file describing mkdocs 1.0.4 in a newer package set:
My plan was to use this expression to create an overlay in the default.nix file. I copy/pasted the expression into the default.nix file as the variable mkdocs-1_0_4, then used that in an overlay to change the build environment to point to this package. (I’m not totally sure this is the proper way to go about this).
mkdocs-1_0_4 =
{ lib, python, fetchFromGitHub }:
with python.pkgs;
buildPythonApplication rec {
pname = "mkdocs";
version = "1.0.4";
src = fetchFromGitHub {
owner = "mkdocs";
repo = "mkdocs";
rev = version;
sha256 = "1x35vgiskgz4wwrvi4m1mri5wlphf15p90fr3rxsy5bf19v3s9hs";
checkInputs = [
nose nose-exclude mock
NOSE_EXCLUDE_TESTS = lib.concatStringsSep ";" [
"mkdocs.tests.gh_deploy_tests.TestGitHubDeploy"
"mkdocs.tests.config.config_tests.ConfigTests"
"mkdocs.tests.config.config_options_tests.DirTest"
checkPhase = "nosetests mkdocs";
propagatedBuildInputs = [
tornado
livereload
click
pyyaml
markdown
jinja2
backports_tempfile
meta = {
homepage = http://mkdocs.org/;
description = "Project documentation with Markdown";
license = lib.licenses.bsd2;
overlay = self: super: {
mkdocs = super.buildEnv {
name = "mkdocs";
paths = [ mkdocs-1_0_4 ];
in { nixpkgs ? import <nixpkgs> { overlays = [ overlay ]; } }:
pkgs = [
nixpkgs.nodejs
nixpkgs.yarn
nixpkgs.stack
nixpkgs.mkdocs
name = "env";
buildInputs = pkgs;
Unfortunately this results in an error:
error: while evaluating the attribute 'buildInputs' of the derivation 'env' at /nix/var/nix/profiles/per-user/root/channels/nixos/pkgs/stdenv/generic/make-derivation.nix:177:11:
while evaluating the attribute 'passAsFile' of the derivation 'mkdocs' at /nix/var/nix/profiles/per-user/root/channels/nixos/pkgs/stdenv/generic/make-derivation.nix:177:11:
cannot convert a function to JSON
I spent some time Googling around for this error but came up short. Thinking on failure, a few things come to mind:
- Perhaps this expression can’t just be copy/pasted in like this
- Perhaps I have made a mistake when creating the overlay
- Perhaps the dependencies of this package also need their own overlays to move to the appropriate versions (I’d expect a different error in that case)
I posted here in the hopes of
- Figuring out this issue and getting a working
default.nixfor this project - Learning best practices for creating this sort of file in the future
With regards to #2, I’d love to hear about how others approach this issue. Thanks in advance!
