The following flake shows that the node script that is wrapped with buildFHSEnv is unable to create a directory inside a derivation.
inputs.nixpkgs.url = "github:NixOS/nixpkgs/nixpkgs-unstable";
outputs = inputs:
with builtins;
system = "x86_64-linux";
p = inputs.nixpkgs.legacyPackages.${system};
packages.${system} = rec {
test =
js = p.writeTextFile {
name = "test";
executable = true;
text = ''
#!/usr/bin/env node
fs = require("fs")
path = require("path")
fs.mkdirSync(path.join(process.env.HOME, "TEST_______"))
p.buildFHSEnv {
name = "test";
targetPkgs = p: [ p.nodejs ];
runScript = js;
default = p.stdenv.mkDerivation {
name = "test";
src = ./.;
installPhase = ''
mkdir $out; cd $_
export HOME=$out
${test}/bin/test
formatter.${system} = p.nixpkgs-fmt;
Upon running nix-build you get the following error:
Error: EROFS: read-only file system, mkdir '/nix/store/<hash>-test/T>
at Object.mkdirSync (node:fs:1364:26)
at Object.<anonymous> (/nix/store/<hash>-test:4:4)
at Module._compile (node:internal/modules/cjs/loader:1554:14)
at Object..js (node:internal/modules/cjs/loader:1706:10)
at Module.load (node:internal/modules/cjs/loader:1289:32)
at Function._load (node:internal/modules/cjs/loader:1108:12)
at TracingChannel.traceSync (node:diagnostics_channel:322:14)
at wrapModuleLoad (node:internal/modules/cjs/loader:220:24)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:170:5)
at node:internal/main/run_main_module:36:49 {
errno: -30,
code: 'EROFS',
syscall: 'mkdir',
path: '/nix/store/<hash>-test/TEST_______'
Node.js v22.14.0
I don’t understand why this particular error is thrown for a couple reasons:
- I can use
mkdirin the exact same environment and it works just fine, so I know where I’m trying to get it to write is not actually immutable. - If I
nix build .#test, and run it ouside a dervation, it works as expected, so it seems to handle paths in a way that one would expect.
That being said, if I don’t wrap the script in buildFHSEnv it works, so I know some combination of buildFHSEnv and the nix build environment is the issue. Would love some insight here.
