Dear all,
I have a small C and a small Haskell project for my Raspberry Pi 4 B. The Raspberry runs the NixOS AArch64 image. Now I would like to cross-compile from my x86_64 desktop, also running NixOS. Compiling works fine, both natively and when cross-compiling, both with GCC or CLang for the C program and with GHC and Haskell.nix overlay for Haskell. I tried nixpkgs.pkgsCross.aarch64-multiplatform
as well as pkgs.pkgsCross.raspberryPi
for cross-compilation but the binaries fail to run with no such file or directory
. I guess the problem is the dynamic library loader?
# From nix-shell -p gcc on the Raspberry
$ cat $NIX_CC/nix-support/dynamic-linker
/nix/store/4pc5akylpxdi0azn6mcqcg0qaj4wz88r-glibc-2.32-10/lib/ld-linux-aarch64.so.1
# The cross compiled binary on the Raspberry
$ patchelf --print-interpreter $CROSS_EXE
/nix/store/iqn7226k4w31g93hd9hjxxazdpfq5j8x-glibc-2.31-aarch64-unknown-linux-gnu/lib/ld-linux-aarch64.so.1
$ patchelf --print-needed $CROSS_EXE
librt.so.1
libutil.so.1
libdl.so.2
libpthread.so.0
libgmp.so.10
libc.so.6
libm.so.6
libffi.so.7
libnuma.so.1
So what is the proper way to cross compile for the Raspberry Pi 4 and is there a way to ensure that all the libraries are installed on the target machine?
And a question out of interest: if it should run on lets say Raspberry Pi OS with totally different paths, would I simply use patchelf to set the RPATH and interpreter to their locations on Raspberry Pi OS?
Thanks in advance
Phillip
