I work with custom embedded devices provided by customers, which typically include a root filesystem, cross-compilation toolchain, Yocto layers, and sometimes Buildroot. While I am able to cross-compile binaries, it can be tedious to compile up-to-date tools for debugging the system.
Recently, I stumbled upon Nixpkgs, which seems to simplify the process of cross-compiling specific versions of binaries. My initial tests using ARMv7 worked flawlessly. However, I encountered issues when trying to build for MIPS1 using the following code:
with import <nixpkgs> {
crossSystem = {
config = "mipsel-unknown-linux-gnu";
bigEndian = false;
arch = "mipsel";
float = "soft";
libc = "uclibc";
mkShell {
buildInputs = [ pkgsStatic.gdb ];
postBuild = ''
mkdir -p $out/bin
cp ${gdb}/* $out/
While the build was successful, it generated a MIPS32 binary instead of a MIPS1 binary. Additionally, I was unable to copy the binary from the Nix store to a local folder.
I have two questions:
- Can I use an external toolchain, such as the one provided by the customer?
- Is this the correct approach to accomplish cross-compilation for MIPS1?
I have found multiple articles about cross-compilation but am unsure of the best practices. Any guidance or suggestions would be greatly appreciated.
Thank you!
