I’m trying to get a cross-compiler toolchain for the m68k-elf target similar to this:
https://aur.archlinux.org/packages/m68k-elf-toolchain/
I’ve found a really pretty solution in the wiki which works for a large number of CPUs that can be parsed by lib/systems/parse.nix
This doesn’t however work in this case, since specifying config=m68k-elf
results in an Unknown CPU type: m68k
error.
I did also try to directly specify a platform attribute like this:
crossSystem = {
config = "m68k-elf";
platform = {
bits = 32;
family = "m68k";
But this doesn’t work.
It seems the most straightforward way would be to fork nixpkgs and add the m68k CPU to the list of options.
However I’d like to know if there is a way to do this without forking nixpkgs.
